Pigfords OLD effort......now JULES NEW PROJECT!!!!!
Update...............
As it was a bit "brass-monkey's" over Xmas I didn't reallt do much to the bike...... until the last week or so. I have removed the head c/w .420 cams & started freshening the standard head I possess.
I have a choice of standard cams and some nice clean webb .395's
I have lapped the valves in, fitted new stem seals and springs. I think I'll try the Webb cams first. These are the old Z900 "roller chain" 3-point mounting for the cam sprockets, so I have ordered some adjustable APE sprox to convert them to the HYVO chain.
Soon as they arrive I shall set the valve clearances on the bench. The shims and buckets are normal top fitted shims so will be easy.
So hopefully it'll be sorted in a few weeks time
Hi Brent - The heads on the bike - nice and snug like
The collector pipe where the downpipes meet was starting to split - so I took it into work and got it welded up
I was gonna get it all back and start her up today, but the clutch on me Trumpet was playing up, so I was fiddling with that this afternoon.
Hopefully I'll get a chance to make some more headway tomorrow - after the Bell Ringing & Choir practice, obviously
How's your Devil Monster Beast coming along me old mucker
Been in the garage tonite - and cobbled the bike back together roughly to test out the replacement head
Well, it appears to work
Trouble is, there is oil pissing out of the front left (#1 piston) cylinder head joint
Not unexpected coz I just swapped the heads over with the same gasket - as I didn't want to throw more cash at it to find the new head was fooked.
Anyhow, the bike started on the button
and sounded real sweet. I couldn't warm it up properly coz of the oil running out, but I'm confident its gonna be OK .......... So as soon as I can get me hands on a COMETIC head gasket to suit 75mm pistons, she'll be ready to roll
- paul doran
That's what I have. I ordered one from Gremlin.... Just assumed it would be a one piece...... Silly me
I am wondering do I try & use an old (good condition) 'O' ring, or use a brand new one from a pattern gasket set, or............. Spend a load more wedge on a new genuine Kawasaki job
I think I know the answer.................... & it ain't the cheap option.
Users browsing this forum: Robw and 129 guests
