Have you got one of "these" lying about?
wobbler
#1 PostAuthor: wobbler » Wed Jun 22, 2011 8:23 am
Hi, has anyone got a z1000 A1/2 sprocket carrier axle spacer lying around that they might be able to measure up?
They are no longer available from Kawasaki so it looks like I need to get a replacement made (would be dead handy to know the diamentions of "A" "B" and "C" in pic below.....)
Andy :D
Padders
#2 PostAuthor: Padders » Wed Jun 22, 2011 8:31 am
I have one I was just about to post for sale for Mick as his computors on the blink. Drop me a pm and I am sure we can sort something out.
Gus
#3 PostAuthor: Gus » Wed Jun 22, 2011 12:57 pm
Ian. Can you put the dimensions up anyway?
Gus
"Set the GRINDER on it"
Padders
#4 PostAuthor: Padders » Wed Jun 22, 2011 3:45 pm
There are two types for the Z1000 range one for the wire wheels and one for the cast. Mick has both and I am not sure which is which the smaller one measures 42mm overall length the longer one 45mm
wobbler
#5 PostAuthor: wobbler » Thu Jun 23, 2011 8:06 am
Cheers Padders, PM sent
#6 PostAuthor: ADRIAN H » Fri Jun 24, 2011 5:59 pm
Phil denton engineering will make them up for you
