Thinking of having a go at the A4 thats on the dreaded ebay - ,180109213021, as can't afford Daveys Z!A
Looks tidy but have noted some non standard parts, apart from the obvious rear shocks, goodridge hoses and chrome clock covers, that is.
The speedo looks wrong and appears to be from the later models with the blue kph markings. Can't make outif the rev counters' red line is at 9 or 9.5.
Everything else looks standard uk spec but wonder if anyone can confirm my thoughts on the clocks and spot any other non standard parts? - My UK z1000 A1 has a po position on the right hand switch gear - should the UK A4 also have this?
help would be appreciated
cheers
Keith - Still searching for the elusive Z
Z900 A4 UK Spec
- london calling
