blowing fuses
PIRELLI
blowing fuses
#1 PostAuthor: PIRELLI » Wed Jun 29, 2011 5:28 pm
can anyone give me a clue as to why my 73 z1 has started blowingthe main fuse. i fitted a dyna ignition and coils over the winter, the bike did about 500 miles then started blowing fuses. it runs for about a minute no probs then blows the fuse. tested the regulator and wasnt getting the correct results so bought a new reg/rec unit. just fitted it, started her up, ran for about 2 minutes and blew the fuse. any help would be greatly appreciated.
KeithZ1R
#2 PostAuthor: KeithZ1R » Wed Jun 29, 2011 6:40 pm
Classic leakage short somewhere does it blow quicker if you turn on the lights or indicators check oround the stem where the wires pass by the the tanks for signs of obvious heat, black bits etc trial and error and looky see is the only way but start with the circuit you disturbed to replace the sparkies
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
PIRELLI
#3 PostAuthor: PIRELLI » Wed Jun 29, 2011 6:48 pm
thanks keith, hard to tell because usually it blows after a minute or two then occasionally it blows within a few seconds. checked round the loom and cant see anything obvious. guess i will have to start disconnecting everything.
CAT3
#4 PostAuthor: CAT3 » Wed Jun 29, 2011 6:55 pm
Does it blow the fuse with the ignition just switched "ON" & the engine not running, or only when the engine is running ?
steve bowdler
#5 PostAuthor: steve bowdler » Wed Jun 29, 2011 7:49 pm
Also check condition of wires going into fuse box ,best change to blade fuses as quality of some glass fuses are shite
#6 PostAuthor: PAULJAC47 » Wed Jun 29, 2011 7:51 pm
Try this chap
Replace the fuse with a 21 watt indicator bulb. As the electrical circuits are switched on the bulb will glow dimly, if a faulty circuit is connected the bulb will glow brightly. If the bulb glows bright with nothing switched on, remove wires from components in turn until the bulb goes out, the last one removed will be the area of the faulty circuit.
Apologies to Boyer but this does work Cheers Paul J :wink:
KeithZ1R
#7 PostAuthor: KeithZ1R » Wed Jun 29, 2011 8:11 pm
Good Call Paul :idea: but I would like to add KEEP A LOOK OUT FOR SMOKE and if you spot any get it off quick smart :!:
Keith
:bop :gom
mistaken.
stephen parr
#8 PostAuthor: stephen parr » Wed Jun 29, 2011 9:46 pm
That's a good idea Paul!!!
PIRELLI
#9 PostAuthor: PIRELLI » Wed Jun 29, 2011 11:34 pm
dont know, will try putting a new fuse in without starting it up, see what happens
Re: blowing fuses
#10 PostAuthor: PAULJAC47 » Thu Jun 30, 2011 8:31 pm
PIRELLI wrote:can anyone give me a clue as to why my 73 z1 has started blowingthe main fuse. i fitted a dyna ignition and coils over the winter, the bike did about 500 miles then started blowing fuses. it runs for about a minute no probs then blows the fuse. tested the regulator and wasnt getting the correct results so bought a new reg/rec unit. just fitted it, started her up, ran for about 2 minutes and blew the fuse. any help would be greatly appreciated.
Can you outline above more in depth and how you fitted combined unit?
You should be getting 50 v ac across any 2 of the genny phases and no more than 14.6 v dc across the battery terminals when bike is running.
Taffus
#11 PostAuthor: Taffus » Thu Jun 30, 2011 8:38 pm
seem to remember the main fuse terminals on this model corrode and go high resistance causing the fuse to blow..............or could be the scrumpy jack tonight........
sid123
#12 PostAuthor: sid123 » Thu Jun 30, 2011 8:52 pm
Try disconnecting the wires from the front brake presure switch ( on the splitter on the front yoke ) these can go down to earth internally.
You cn confirm this by testing each pin on the switch for continuity to earth - if you have continuity on either of the terminals switch is cause and you need a new one
SID
whoosh im gone
Taffus
#13 PostAuthor: Taffus » Thu Jun 30, 2011 9:09 pm
sid123 wrote:Try disconnecting the wires from the front brake presure switch ( on the splitter on the front yoke ) these can go down to earth internally.
SID
in with a bullet! :D I'll store that one ! (great hint by the way)
sid123
#14 PostAuthor: sid123 » Sat Jul 02, 2011 1:37 pm
was it sorted ?
sid
whoosh im gone
Users browsing this forum: sockpuppet, wilsonsjw11 and 67 guests
