Z900 A4 Neutral Switch not working. How to replace?
Avelar
#1 PostAuthor: Avelar » Tue Apr 24, 2007 6:40 am
Hi,
My neutral switch has stopped working on my 1976 Z900 A4. My Haynes manual does not show much about replacement. Is it a big job?
Any advice appreciated.
#2 PostAuthor: chrisNI » Tue Apr 24, 2007 11:17 am
The neutral switch is in beside the engine sprocket it just screws out - if that's what the problem is it's easily enough replaced. They don't often break.
#3 PostAuthor: Rich » Tue Apr 24, 2007 5:42 pm
More likely to be the connector / wiring than the switch.
phil churchett
#4 PostAuthor: phil churchett » Tue Apr 24, 2007 6:43 pm
Have to agree with Rich, also could be a build-up of chain lube/crap.
