Back in the pre-meltdown days I was having problems with the shims in my Z1R after lightly grinding the valves took the clearances below tollerance.
I needed some 1.90's but all the previously mentioned Yamahaha sources for this size had de-listed them (Kawasaki only list them down to 2.00).
Several folk spoke of grinding down shims and PaulJ kindly sent me three that had already been ground; albeit not to the 1.90 I needed so I could try a bit more grinding myself.
Errr.... nice idea but it didn't work.
Trying to grind the shims further using grinding paste on a glass sheet (to keep it all flat) does pretty much bugger all (yes I was working on the previous ground side!). After half an hours effort I had managed to clean up the grinding marks on one shim but made naff all difference to the thickness.
So; unless you have access to some mechanical surfacing grinding kit; don't bother trying to do it by hand.
What did I end up doing? Tipping the valves as suggested by Jerry(?) and detailed in the workshop manual got them back into the range where normal shims could be used.
Ground Shims
Rufflel, a good point, however, before getting all your valves "tipped", it a good idea to check them in the head with cams to see you do not have to put a 300 (3mm) or greater shim in!
This check is carried out by assembling buckets and valves without springs, with say a 200 (2mm) shim in place and measuring the clearance, whilst apply pressure (by hand) on the valve head to the cam. Then measure the gap.
I say this, merely because, I once sent a set of valves to be faced & tipped and the machinist was a bit ambitious and machines too much off. Resulting in two things.... too bigger shims required and tops of valve collet had to be relieved. I now say, take a bare minimum off the tip.
Good advice. I took about 0.2-0.3 off each valve so the ones that needed 1.90 went
to needing ~2.20's.
The workshop manual gives a minimum distance twixt the top of the valve and the
collett groove and I was well over that.
My big lesson learnt is that you should do a 'dry' build of the head on the bench
and check the cleanrances before bolting everything back onto the bike.
to needing ~2.20's.
Users browsing this forum: Google [Bot] and 70 guests
