trick z1000
AD1
#646 PostAuthor: AD1 » Thu Jun 23, 2011 7:43 am
Absolutely Stunning!
brian 450
#647 PostAuthor: brian 450 » Mon Jul 04, 2011 8:42 pm
I have been out for a spin to make sure every thing is working ok. Well i have to say its F****ng awsome!!!!!!! it handle like it is on rails the engine has plenty of grunt and the brakes are really sharp. I couldn't fault it.
#648 PostAuthor: Pigford » Tue Jul 05, 2011 11:48 am
There you go matey - bet you're glad you stuck at it :P
scott
Junior Section leader
#649 PostAuthor: scott » Tue Jul 05, 2011 2:05 pm
That is absolutely stunning Brian.....very nice indeed.
bart
#650 PostAuthor: bart » Tue Jul 05, 2011 3:15 pm
Absolutely stunning bike,all that hard work has really paid off,a real credit to you Brian. :drool
Mr Puffin
#651 PostAuthor: Mr Puffin » Wed Jul 06, 2011 1:27 pm
brian 450 wrote:Image
Stunning brian :D welldone :!:
Mr Puffin
brian 450
#652 PostAuthor: brian 450 » Fri Aug 19, 2011 8:22 pm
I am finding the Z a bit slow and revy compared to my ducati ect. So i am going to try a 19 tooth front sprocket and if that don't work i think i will put a gsxr lump in it over the winter. :roll: :roll:
#653 PostAuthor: Pigford » Sat Aug 20, 2011 6:43 am
brian 450 wrote:I am finding the Z a bit slow and revy compared to my ducati ect. So i am going to try a 19 tooth front sprocket and if that don't work i think i will put a gsxr lump in it over the winter. :roll: :roll:
:shock:
ollie
#654 PostAuthor: ollie » Tue Aug 23, 2011 1:55 pm
thats criminal :shock: ,
davy thomson
#655 PostAuthor: davy thomson » Tue Aug 23, 2011 3:00 pm
And very scary :shock: Been there done that had a GS with a tuned GSXR1100L motor,those clip-ons will come in handy if you go down that road.
1000 posts reached that will do for me,over and out.been fun.
brian 450
#656 PostAuthor: brian 450 » Fri Sep 02, 2011 6:35 pm
I have developed a oil leak from the wires that come out of the alternator cover. What i need to know is can i remove the cover to seal it up without draining the oil.
#657 PostAuthor: Rich » Fri Sep 02, 2011 6:37 pm
if you lean it to the right you can
brian 450
#658 PostAuthor: brian 450 » Fri Sep 02, 2011 7:05 pm
Thanks Rich
brian 450
#659 PostAuthor: brian 450 » Tue Sep 06, 2011 6:01 pm
I am fitting a new alternator loom. What i need to know is what should i use to seal the rubber gromet in the casing as silicon seems to break down with the oil.
#660 PostAuthor: Rich » Tue Sep 06, 2011 6:44 pm
Blue Hylomar or Threebond 1194 / 1211
