caliper upgrade
wayno
caliper upgrade
#1 PostAuthor: wayno » Tue Jul 26, 2011 8:29 am
which caliper is easiest to adapt to fit a z1000, like the look of a harrison but not the price when new discs are added :shock:
HowieD
#2 PostAuthor: HowieD » Tue Jul 26, 2011 8:56 am
Anything is possible
regards
Howie
steve bowdler
#3 PostAuthor: steve bowdler » Tue Jul 26, 2011 9:02 am
spondonges
#4 PostAuthor: spondonges » Tue Jul 26, 2011 5:08 pm
Dont use "Stealthproducts" I put an order in with them and paid in full, 6 months later I was still waiting and when I contacted them I was fobbed off... :x :x
It took me another two months to get a refund after repeatedly threatening them with Court action..
Their customer service is pants :shock: :shock: :shock:
I'd rather be riding my Z1 thinking about God than sitting in a church thinking about my Z1..
steve bowdler
#5 PostAuthor: steve bowdler » Tue Jul 26, 2011 6:12 pm
Thats strange I received my discs in the time stated :??
DANNY.T
#6 PostAuthor: DANNY.T » Tue Jul 26, 2011 9:34 pm
Stealthproducts are theiving scum i ordered discs a year and a half ago,they sent me the wrong discs of which i returned at my expense.After being fobbed off for 4 mths as to why i had'nt been sent the correct replacements yet,i asked for a refund.Which i have yet to receive!
Trading standards are a waste of space because even if you win the case at small claims court there's nobody to enforce the company to pay. :grr
Blackfox
#7 PostAuthor: Blackfox » Wed Jul 27, 2011 4:12 pm
Kaw 1980 LTD dual brake set ups work great and keep the cost down :wink:
Fox
spondonges
#8 PostAuthor: spondonges » Wed Jul 27, 2011 6:17 pm
DANNY.T wrote:Stealthproducts are theiving scum i ordered discs a year and a half ago,they sent me the wrong discs of which i returned at my expense.After being fobbed off for 4 mths as to why i had'nt been sent the correct replacements yet,i asked for a refund.Which i have yet to receive!
Danny T , you're not the only one, I heard loads about this firm since the problems I had...When all my shit was gooing I had a company search data update going on them from an independent firm and they were clocking up the CCJ's about 2 a year !!!!
Z1 owners, steer clear of these muppets :x :x :x
brian 1100
#9 PostAuthor: brian 1100 » Fri Jul 29, 2011 6:46 pm
Something you might want to consider is the master cylinder.
Always found the standard brake set up on my Lawson was pretty good if I used sintered pads.
Got a modern radial master cylinder on a whim but really for the looks and didn't really expect it to make any difference.
The increased braking power is quite amazing - two fingered braking no problem.
You do need braided hoses and good brake piston seals to cope with the extra pressure.
Mine's an Accossato which is just a cheaper version of the Brembo.
Brian
nanno
#10 PostAuthor: nanno » Fri Jul 29, 2011 7:33 pm
No need to go for radial masters, a simple 5/8" from a Bandit 1200 will work wonders already. :roll:
Padders
#11 PostAuthor: Padders » Fri Jul 29, 2011 7:36 pm
Go with ZRX1100/1200 mastercylinder works great keeps the mirror and if you wish you can use the matching clutch mastercylinder and convert to hydraulic clutch.
brian 1100
#12 PostAuthor: brian 1100 » Fri Jul 29, 2011 8:04 pm
Don't know what size the Z1000 has. The Z1100R already had a 5/8 (16mm). The new radial I think is 19mm - in theory too large but radials need to be bigger. But yes, any more modern 5/8 cylinder might be better.
The modern water cooled Z1000's and CB1000r's have radial cylinders with mirror mounts and can often be picked up on ebay.
Might be better than a normal cylinder but they do have separate reservoirs which a lot of people won't like on a classic.
Brian
Users browsing this forum: No registered users and 243 guests
