Went out for a spin and the tacho cable broke as i set off....
and on the way home the gear lever stuck down when changing from 5-4...changed back up and it stayed there too, got home Ok and got it back to N by hand.
Any suggestions? is it a hard job to change it?
Gear lever return spring broken?
- Mark Tiller
07962421462
- Mark Tiller
- Mark Tiller
- Mark Tiller
Removed gear lever linkage and swivelled it backwards....
took outer cover and sprocket off (was loose!) then removed inner cover and the spring is fine????...
It was then i noticed the Tarozzi gear pedal was still stuck in position...Doh
The knurled nut had worked loose and caused the lever to bind...
F**K!
Ah well new gasket from Zpower on the way...
F**K!
07962421462
