Gear lever return spring broken?
Mark Tiller
#1 PostAuthor: Mark Tiller » Sat Jul 30, 2011 9:50 pm
Went out for a spin and the tacho cable broke as i set off....
and on the way home the gear lever stuck down when changing from 5-4...changed back up and it stayed there too, got home Ok and got it back to N by hand.
Any suggestions? is it a hard job to change it?
07962421462
#2 PostAuthor: zed1015 » Sat Jul 30, 2011 10:40 pm
Easy enough job.
Sprocket cover off.
Sprocket off.
Then remove the cover that holds the seals and there it is.
Pop in a new spring, reassemble and away you go.
Will need a new gasket though if you are unlucky.
Should only take an hour max.
Mark Tiller
#3 PostAuthor: Mark Tiller » Sat Jul 30, 2011 10:46 pm
Cheers zed1015...l will whip the cover off in the morning and have a look
07962421462
malc87
#4 PostAuthor: malc87 » Sat Jul 30, 2011 10:58 pm
Did it on my Z1A with 42000 on the clock :(
Mark Tiller
#5 PostAuthor: Mark Tiller » Sat Jul 30, 2011 11:00 pm
malc87 wrote:Did it on my Z1A with 42000 on the clock :(
nearly 45000 so maybe was overdue?
07962421462
Mark Tiller
#6 PostAuthor: Mark Tiller » Sun Jul 31, 2011 10:08 am
Removed gear lever linkage and swivelled it backwards....
took outer cover and sprocket off (was loose!) then removed inner cover and the spring is fine????...
It was then i noticed the Tarozzi gear pedal was still stuck in position...Doh
The knurled nut had worked loose and caused the lever to bind...
F**K!
Ah well new gasket from Zpower on the way...
07962421462
