coldsummer wrote:I've decided to buy myself an ultrasonic cleaner as a reward for giving up drinking.
Jumbo wrote:coldsummer wrote:I've decided to buy myself an ultrasonic cleaner as a reward for giving up drinking.
You should be able to buy quite a big cleaner then![]()
GPRD wrote:I bought one of these last year and it was pretty good, paid about £40 for it. They're easy to use, put the item in, switch it on, choose length of time and whether you want to heat the water. Throw some cleaner in to help it and voila. The hassle is strrpping the part you're cleaning. Main thing to look out for is size and whether the bit you want to clean is going to fit. The one I bought will fit a carb or two if stripped down, but one not four on a backing plate! I got mine from Holland.
Rich wrote:GPRD wrote:I bought one of these last year and it was pretty good, paid about £40 for it. They're easy to use, put the item in, switch it on, choose length of time and whether you want to heat the water. Throw some cleaner in to help it and voila. The hassle is strrpping the part you're cleaning. Main thing to look out for is size and whether the bit you want to clean is going to fit. The one I bought will fit a carb or two if stripped down, but one not four on a backing plate! I got mine from Holland.
Would you recommend it? a carb or two sounds a decent size for me does it do a good job? If so what model please.
Users browsing this forum: Bing [Bot], knut and 70 guests
