LED idiot light and clock bulbs
- Mark Tiller
Anyone know if these are available? i see wemoto do the filament type but is a LED equivalent
07962421462
- Mark Tiller
Thanks both for the advice....i found some on good ol fleabay
http://www.ebay.co.uk/itm/1x-BLUE-Wide- ... 588ce89c3d
gone for the different colour option...ill report back when i have tried them with a couple of photos
07962421462
- Mark Tiller
these 2 photos are with normal filament bulbs
these 2 are with colour LED BA9S fitted...the light is not difused as filament bulbs and the brake idiot light is constantly on and just gets brighter when u pull the brake? but the colour is fine
these are wth white LEDs fitted... with white LEDs fitted the colours look a bit wishy washy and the neutral looks more like light blue, in the last photo the brake light is back to a filment
07962421462
- Mark Tiller
to difuse the light a bit i rubbed the plastic glass part with fine wet and dry untill it was opaque and they now look the biz.
www.aceparts.com
www.aceparts.com
07962421462
The brake idiot light is always on, because it relies on the resistance of the bulb, to trigger off the light. Same goes for the pilot-light, which will also be lit, if you trigger the brake-light.
Cheapest way to solve: fit a normal warning light bulb or add a resistor.
Greg
Greg
- Mark Tiller
- Mark Tiller
