Are these smoothbores?
kawman736582
Re: Are these smoothbores?
#16 PostAuthor: kawman736582 » Thu Aug 04, 2011 11:55 am
Mark Tiller wrote:Are these smoothbores, they are on a 1977 KZ1000 A1 import
yes
Garn 1
#17 PostAuthor: Garn 1 » Thu Aug 04, 2011 12:47 pm
Tell me if I'm wrong...... If it is Mikuni and has a single bowl plug approx 17 mm and it isn't an early Z1 carb set... It's a set of Smoothbores?
RegardZ
#18 PostAuthor: zed1015 » Thu Aug 04, 2011 1:12 pm
Garn 1 wrote:Tell me if I'm wrong...... If it is Mikuni and has a single bowl plug approx 17 mm and it isn't an early Z1 carb set... It's a set of Smoothbores?
RegardZ
Generally speaking - Yes (If they ain't been mucked about with).
BUT! Some smoothbores come without the main jet access.
The suzuki Katana 1000 came with either 32mm or 34mm mikuni smoothbores and had plain floatbowls fitted.
#19 PostAuthor: Rich » Thu Aug 04, 2011 2:53 pm
Very early VM29s came with a small drain screw.
They look to be VM29s.
A few other bits to look for:
take the airscrew out and it should have a big through hole and a tiny bleed hole in the end,
most floats will be brass, but I also have a set with plastic floats, the fuel valve in each carb will have a small filter over it as well. if you can't get the inlet rubber off to have a look.
Keefleaf
#20 PostAuthor: Keefleaf » Fri Aug 05, 2011 11:51 am
RegardZ
Early 28mm Carbs have 2 screws holding top on.May have 17mm floatbowl nut/might not.
26mm/28mm,[ A4-z1000 ]carbs have 3 screws holding top on.
29mm Smoothbores look like A4/z1000 carbs,[ 3 screws on top ]but have
the 17mm floatbowl nut...as pictures above. Simple? :wacko
z1000puddin
#21 PostAuthor: z1000puddin » Fri Aug 05, 2011 6:41 pm
Mark,
I really think you should remove these from your bike !! :D
Take them off mate & put the standard 26mm carbys back on... :shock:
I have a spare set of 26mm Z1000A1 carbs in me garage.
I will do a straight swop :wink: :wink: :wink:
lol
stu
Zed til Dead
Mark Tiller
#22 PostAuthor: Mark Tiller » Fri Aug 05, 2011 7:13 pm
z1000puddin wrote:Mark,
lol
stu
Thats a very generous offer Stu...let me think about it :lol:
07962421462
DDZ900
smoothbores
#23 PostAuthor: DDZ900 » Fri Aug 05, 2011 7:26 pm
These carbs look the very same as i had on my z1000 race outfit in the 80s , they were mikuni 29mm smoothbores ? :wink:
