Rotor removal - Z900 A4
martinz1000r
#16 PostAuthor: martinz1000r » Sat Aug 06, 2011 2:46 pm
Steve - puller worked a treat. Popped off with minimal effort. Just goes to show how easy things are with the right tools. It will be in the post to you on Monday or Tuesday. Many thanks for the loan.
#17 PostAuthor: Ginger Bear » Sat Aug 06, 2011 4:38 pm
No problem Martin, glad it did the trick. :D
# 104
Garn 1
#18 PostAuthor: Garn 1 » Mon Aug 08, 2011 12:46 am
Good result.. So, did you need any heat?
martinz1000r
#19 PostAuthor: martinz1000r » Mon Aug 08, 2011 11:40 am
No heat required. Just quarter turn on the puller and it let go easily. Now I need to sort a replacement solution. West Country Windings here I come...
Users browsing this forum: Bing [Bot] and 82 guests
