will a gpz 1100 head fit a z1000j.
andy.s
#1 PostAuthor: andy.s » Mon Aug 15, 2011 2:02 pm
hi guys as the title, any answers greatfull, and is it a like for like replacement.
cheers
andy. :)
will be done soon !!!!!.
#2 PostAuthor: Ginger Bear » Mon Aug 15, 2011 2:11 pm
Should fit no problem, only one small difference I know is that the 'J' engine used 'o' rings between the head & barells on the outer studs, where as the Geepster doesn't. (At least the Uni-trak Geepster doesn't) Use something like a Cometic head gasket & it should all be fine.
# 104
london calling
#3 PostAuthor: london calling » Mon Aug 15, 2011 5:29 pm
Better off with a twin shock B1 or B2 head than the GP ZX uni-trak head as it has a different combustion chamber design.
The B1 head will need the injection ports blanking off,but that's it.
Z1000 LTD (K) is the same as 1000J
Jack
andy.s
#4 PostAuthor: andy.s » Mon Aug 15, 2011 7:21 pm
cheers gb and jack 1st class.
andy. :D
Taffus
#5 PostAuthor: Taffus » Mon Aug 15, 2011 7:29 pm
do you have a GPz 1100 head for sale??
#6 PostAuthor: Al » Mon Aug 15, 2011 10:06 pm
The uni-trak exhaust valves are at a different angle to the exhaust valves on the J head but only the exhaust valves. They are more 'stood up' allowing a larger exhaust valve diameter than would otherwise be possible.
The only occassion when this is relevant is when fitting high top high comp pistons where you have to have the exhaust valve pockets in the pistons relieved to clear the head of the valves.
Ray Debben did mine for me recently when i bought wiseco 1170 high comp pistons for my J1 to go with a uni-trak head.
andy.s
#7 PostAuthor: andy.s » Tue Aug 16, 2011 4:26 pm
thanks for the time and effort guys. taffus i dont have a gpz1100 head for sale sorry,the question related to a z1000j my mate is looking to buy and was wondering about the head on it.
andy. :)
Users browsing this forum: Google [Bot], knut and 64 guests
