Starting problems
Starting problems
Hi all, as usual bike didn't want to go to its MOT and wouldn't start.
Here is the problem.
Starter relay clicks when starter button depressed. I have checked the voltage across the starter relay and it is 12V but drops to 1V when starter button depressed. I have also checked all the cables and connections and they seem okay.
When I was at the Festival of 1000 bikes, before the last session it would only turn over very slowly, so I fitted a new battery and also a chap with a starter box had ago and it did not make any difference, but eventually it caught and ran with no problems during the session. (Thinking about it, it started turning over slowly well before the weekend hence me buying a new battery)
The starter relay was replaced when I rebuilt the bike so it hasn't had that much use, but I have not touched the starter motor.
Could it be the starter motor has given up and seized?
Cheers Rob
Cheers Rob
Short out the large contacts on the solenoid with a screwdriver,see if that makes a diff,as said on post before this check all earths.if need to wip out starter motor and check brushes and continuity between copper segments on rotor you can always check motor off load gripped in a vice with a pair of jump,leads..Paul J
Rob,
I'd put my money on worn brushes.
Z1enterprises do 'em for the earlier models, probably worth an email to see if they have them to suit your starter.
http://www.z1enterprises.com/Starter-Mo ... -4152.aspx
- big green bus
I had something very similar, tried everything you did and decided it was the starter motor, just before I began to replace the motor I give it a t**t with a steel bar and it started to work fine. I think it just needs stripping and cleaning as per the manual and as Steve says the brushes looking at.
- london calling
Hi, just removed the starter and stripped it down and it is absolutely knackered. It was very hard to turn the shaft and some of the brushes were dust. A wire had broken off one of the brush mounts and the commutator has heavy wear on it. There is a smell of burnt electrical components. So I am going to scrap it.
See my wanted post.
Cheers Rob
See my wanted post.
Cheers Rob
- steve bowdler
- big green bus
Users browsing this forum: Bing [Bot] and 38 guests
