Fuel Tap Problem
Fuel Tap Problem
I have one of those vacuum activated fuel taps on my Z650 and its started spraying petrol out of that little hole in the side of the spacer that holds the diaphram.
It only does it when its running and doesn't leak otherwise.
Anyone got any ideas please?
What we got here, is failure to comunicate.
I had the exact same problem a few years ago........
I cut down a milk carton and jammed it below the fuel tap.
When the carton was almost full, I stopped and poured the fuel back into the tank. Going to and from work only took a few minutes more.
I hope this helps.
Jimmock.
I hope this helps.
Jimmock.
Jimmock.
I hate people I don't like !
GPRD wrote:Yep, it is. I've ordered a full replacement now, sick of taking it apart and putting it back together.
Cheers anyway.
I had the same on my z1100r after the tap leaked and put half a tank of fuel in the engine, I replaced the original tap with a pingel tap. Not a full repair to resolve the problem with the tap or carb float valves but a good solution !!!!
LE to JOG on a z900
P.U.M.
P.U.M.
jimmock wrote:I had the exact same problem a few years ago........
I hope this helps.
Jimmock.
I might try that, but add some tubing and a pump too.
Jumbo wrote:GPRD wrote:Yep, it is. I've ordered a full replacement now, sick of taking it apart and putting it back together.
Cheers anyway.
I read that a suzuki fuel tap will fit, so I've ordered one of those.
Users browsing this forum: Bing [Bot] and 38 guests
