Coil connections
Gyesdad
Coil connections
#1 PostAuthor: Gyesdad » Thu Aug 25, 2011 4:46 pm
I have a GPz750R1 and have some new coils for it.
There is no mention in the workshop manual about which wires go to the positive and negative terminals on the coils.
I have a choice of a red wire and a green wire on the left as you sit on the bike and red wire and black wire on the other, so which go to the +ve and which got to the -ve? Does it matter? I'm assuming it does if the terminals are marked. or maybe not! :??
It does say in the manual that the green wire goes to the coils on plugs 2&3 and the black wire goes to the coils on plugs 1&4, don't know if this nformation helps.
Thanks in advance. :)
#2 PostAuthor: z1bman » Thu Aug 25, 2011 5:06 pm
red wire is the positive make sure you have got your colours right as far as i can remember the green wire is for 1+4 + black is for 2+3
Gyesdad
#3 PostAuthor: Gyesdad » Thu Aug 25, 2011 5:42 pm
Thanks for that! :D
I've got the manual in the garage to make sure they're correctly wired up.
