Fuel Tap
Kerrigan
#1 PostAuthor: Kerrigan » Thu Jul 13, 2006 9:12 pm
Its the Newbie here.....
Had the bike 2 weeks and started to wonder when it would go on to reserve......
You've guessed it, I ran out of fuel completely...!
When it began fading and spluttering, I switched to reserve and nothing happened.....it just stopped.
Luckily I was only about 600 yards from a service station - quick piece of advice: DON'T PLAN ON PUSHING A Z VERY FAR...
Does this mean the reserve tap is faulty and needs cleaning/new fuel tap kit etc? Or was I already on reserve?
I assume the lever points to the various marks by the rounded end with the little raised line/pointer....or is it the lever itself that has to point?....now I'm getting confused!
HELP
Kerrigan
hanskloss
#2 PostAuthor: hanskloss » Thu Jul 13, 2006 10:00 pm
lever down-ON, lever up- RES, I've pushed mine too when I bought it :)
(Edited by hanskloss at 11:01 pm on July 13, 2006)
Kerrigan
#3 PostAuthor: Kerrigan » Fri Jul 14, 2006 3:35 pm
Thanks mate, I've just been out to have a look and yes, I was switching the tap to "reserve" instead of "on"......
This is what happens when you have had bikes for the last 10 years with fuel injection....!
Jumbo
#4 PostAuthor: Jumbo » Fri Jul 14, 2006 3:41 pm
I took my bike to have the carbs balanced. The guy did a cracking job except he drained petrol from my tank to fill his "dummy" tank that he used whilst balancing the carbs. I went home on reserve thinking I would be OK but had to push for a while.
The worst bit was that I got to the petrol station and they had a problem and all the pumps were off. The wife rescued me in the end with a petrol can !!
anthony
#5 PostAuthor: anthony » Sat Jul 15, 2006 2:38 pm
Just on the subject of pushing your Z,my regulater conked one night and ended up pushing it home....MMM not good.Why is it you always see someone you know.
