Flat track style z
debben1
Flat track style z
#1 PostAuthor: debben1 » Wed Sep 28, 2011 7:33 pm
My project bike which was going to be a classic racer but I have had a change of plan and dont want to build a bike following the rule book anymore, so will put something together thats different to anything I have done before :D
Crofty
#2 PostAuthor: Crofty » Wed Sep 28, 2011 7:40 pm
Looking forward to seeing the project, should be good. Crofty
#3 PostAuthor: Pigford » Wed Sep 28, 2011 7:43 pm
I think we'll all be glued to this one Steve :wink:
#4 PostAuthor: chrisNI » Wed Sep 28, 2011 8:32 pm
Good to see you back on Steve always interesting to see what you come up with... :P
GUYZED
#5 PostAuthor: GUYZED » Wed Sep 28, 2011 9:00 pm
chrisNI wrote:Good to see you back on Steve always interesting to see what you come up with... :P
Yep ditto...good to have you back Steve.
#449
Z1000A2 Z650B1
PJ
#6 PostAuthor: PJ » Sat Oct 01, 2011 8:23 am
More pics and info please
debben1
#7 PostAuthor: debben1 » Thu Oct 06, 2011 7:22 pm
not sure about this tail piece, might be to much??
keep changing tanks too, decisions decisions :)
Holeshot
#8 PostAuthor: Holeshot » Fri Oct 07, 2011 1:08 am
Nope - love it.
Looks the nuts!
:D
KWACKERZ1
BIKE
#9 PostAuthor: KWACKERZ1 » Fri Oct 07, 2011 2:11 pm
That swingarm is nice what make is it?
Clean simple classic lines!
Gus
#10 PostAuthor: Gus » Fri Oct 07, 2011 2:33 pm
Personally I think it would look better with a different tail unit and the LTD tank.
But that's only my choice :lol:
Gus
"Set the GRINDER on it"
debben1
#11 PostAuthor: debben1 » Mon Oct 10, 2011 4:36 pm
Thank you all, the swing arm is a GPz1100 unitrak arm modified with ends machined to take the stock Z1000 chain adjusters, ignition switch has been re located to behind the head stock and in front of the horn, next job is the rear sets
Nosher903
#12 PostAuthor: Nosher903 » Mon Oct 10, 2011 5:51 pm
If it's going to look anything like this one PHWOAAAAAR!
Z1b, GPZ900r, XJR1300
rpeters
Bristol's "H" Hoarder
#13 PostAuthor: rpeters » Mon Oct 10, 2011 5:56 pm
yuk...thats hideous :roll:
Baldylocks
#14 PostAuthor: Baldylocks » Mon Oct 10, 2011 6:27 pm
Nosher got to agree with rpeters that looks shite! You could make your "trophy winning" Z1b look like that.. :D but if it were me I'd make it a Racecrafters Replica not a Flat tracker after all it is a Superbike not a dirt bike
Bugger ! whose Idea was that!
'78 Z1r '79 z650/1100 '77 Seeley H**** 750 GPz1100 B2 '86 GSXR750R Ltd '97 KTM620 '76 S3a 400
coldsummer
#15 PostAuthor: coldsummer » Mon Oct 10, 2011 6:53 pm
Steve, I've had one of those Zed-butt seats knocking around for ages and I keep planning on using it. Trouble is, each time I do a mock up with it, it just doesn't look right. I've come to the conclusion that the front end is the problem, ie the big lip that is moulded into it. I think if this is removed leaving just the side mouldings it would look a lot better as the tail section is quite nice.
Just my thoughts :roll:
