KZ900A4 Boiling battery
Geoff Meager
#1 PostAuthor: Geoff Meager » Sun May 13, 2007 11:20 pm
Yes I know.....I'm a Knobber.....I put this on the Discussion Board 1st......
:oops:
But I do need help, the lecky system is pumping out 16v+ ( 14.2 with the lights on ) is it the Rectifier, regulator or both.
Can I fit another item from a different model??????
Geoff
______________
PAID UP MEMBER
WITH NO ZED
Garn 1
#2 PostAuthor: Garn 1 » Mon May 14, 2007 1:04 am
Geoff, the problem is most likely with the regulator, not controlling the voltage and hence, a battery boil. The voltage should be no more than 14 Volts at 3000rpm across the battery terminals. If you are replacing use a reg/rectifier combined unit, which are readily available.
There are many other replacements you can use. I always try to get a second-hand, ZRX650 unit, some swear by the HondX "Dream" unit.
