how do you remove handle grip
bunnysZ
Granny Magnet
#1 PostAuthor: bunnysZ » Sat Nov 05, 2011 7:42 pm
want to change the clutch lever bracket over on the zed,
any tips on how to take the handle grip off so I can slide the bracket off
#2 PostAuthor: Pigford » Sat Nov 05, 2011 7:45 pm
Slide a thin screwdrive up it & squirt WD40 up it with the straw/tube it comes with, then work it round with the screwdriver & pull :wink:
PJ
#3 PostAuthor: PJ » Sat Nov 05, 2011 7:55 pm
Pigford wrote:Slide a thin screwdrive up it & squirt WD40 up it with the straw/tube it comes with, then work it round with the screwdriver & pull :wink:
What pig ford said, works a treat
#4 PostAuthor: Ginger Bear » Sat Nov 05, 2011 7:58 pm
And when you want to put it back on, use brake cleaner, that will lube it for a few seconds, then evaporate, so you don't have a 'slippy' grip. :D
# 104
#5 PostAuthor: Pigford » Sat Nov 05, 2011 8:03 pm
Ginger Bear wrote:And when you want to put it back on, use brake cleaner, that will lube it for a few seconds, then evaporate, so you don't have a 'slippy' grip. :D
.................... opener for Jimmock......... :shock:
jimmock
#6 PostAuthor: jimmock » Sat Nov 05, 2011 9:05 pm
I'm laughing here..... I read it and thought....here we go again,....and the next post by Pigford predicted my thoughts!!!!!
Slippy grip, sounds like my kinda grip!!!!
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
bedlow1
#7 PostAuthor: bedlow1 » Tue Nov 08, 2011 5:36 pm
The other trade trick when refixing is to spray the handlebar with ladies hair spray this will dry out and acts as an adhesive.
1972 Z1 Euro Spec
1975 Z1B UK Bike
#8 PostAuthor: PAULJAC47 » Tue Nov 08, 2011 6:22 pm
Rags wrapped round the grips and soaked in boiling water works as well!!!
morten
#9 PostAuthor: morten » Wed Nov 09, 2011 5:21 pm
I have good experience with using the air compressor and just blow it off!!!!
Then you do not have to cleen or use any chemicals at all just hammer it easily back with a rubber hammer. :D
jimmock
#10 PostAuthor: jimmock » Wed Nov 09, 2011 5:49 pm
morten wrote:I have good experience with using the air compressor and just blow it off!!!!
I too had a good experience with an air compressor that just blew me off!!
Jimmock.
Jimmock. :wnkr
PJ
#11 PostAuthor: PJ » Wed Nov 09, 2011 6:26 pm
Jimmock.
I bet you did!!
jimmock
#12 PostAuthor: jimmock » Wed Nov 09, 2011 6:58 pm
I'll tell you one better than that....
Whilst standing on a London Underground platform I nearly got sucked off by a passing train!!
Jimmock.
Jimmock. :wnkr
#13 PostAuthor: kev edwards » Wed Nov 09, 2011 7:13 pm
jimmock wrote:I'll tell you one better than that....
Jimmock.
you have all the luck Jim
jimmock
#14 PostAuthor: jimmock » Wed Nov 09, 2011 7:25 pm
Jimmock.
I guess that's why they call me "Lucky Jim".
Jimmock.
Jimmock. :wnkr
Bruce Sexton
#15 PostAuthor: Bruce Sexton » Thu Nov 10, 2011 1:31 pm
Jimmock.
Jimmock.
Is that why you can't buy platform tickets anymore :D :D :(
Bruce
