Wots Cooking
sanderz
#61 PostAuthor: sanderz » Mon Nov 07, 2011 10:03 pm
The rear pegs are now welded.
Dropped off late at night and had em back next day!!
Smett yer a fookin' star :up
Quality job!
and with them on after a lick of paint -
Wots up DOHC
sanderz
#62 PostAuthor: sanderz » Mon Nov 07, 2011 10:10 pm
I'll keep 'chipping away' :roll:
Still have to make a 'proper' mount for the back light - some brackets off the tail mount .......all ideas swirling round in the amoeba at the moment so until then its - WIP as usual :roll:
Latoz!
Wots up DOHC
GUYZED
#63 PostAuthor: GUYZED » Tue Nov 08, 2011 1:25 am
Looking well sweet there Sanderz :drool keep the pics coming mate.
#449
Z1000A2 Z650B1
sanderz
#64 PostAuthor: sanderz » Thu Dec 01, 2011 6:19 pm
Background if one so requires -
http://www.youtube.com/watch?v=CkCWVNaX ... re=related
Yeh "a little less conversation, a little more action" wouldn't go amiss on this project :roll: ........ ah well.
Gettin' cold out there (im a soft arse tho as anythin' below 20 deg an its thermals for me) give me summer any day.
Still, stock up on the porridge an "get in there"
So wots new on the menu?
Picked these up recently to "fanny about" with
Still not sure how it'll work out, but it'll be along these lines, using the existing frame bolt hole and the alloy bracket -
Wirings nearing an end, although till i get a new battery an see wot works or rather doesnt, its fingers crossed. We'll see :roll:
New headlight -
and also new tail light -
Both are wired (im not, but then weekends nearly here) so as usual its Work In Progress (yeh i know .....yawn)
See if i can pick a battery up in the next few days, be fingers crossed when i do ha ha
Go easy,
Latoz :wink:
Wots up DOHC
#65 PostAuthor: Pigford » Thu Dec 01, 2011 6:28 pm
Top stuff lad :wink:
nanno
#66 PostAuthor: nanno » Thu Dec 01, 2011 10:00 pm
S'comin' together nicely!
#67 PostAuthor: Ginger Bear » Wed Jan 18, 2012 8:56 pm
Any progress Sanderz :? Not heard from you for a while. :ek
# 104
GUYZED
#68 PostAuthor: GUYZED » Fri Jan 20, 2012 5:41 am
Ginger Bear wrote:Any progress Sanderz :? Not heard from you for a while. :ek
Not a lot...buy the looks of it Steve :( come on Sanderz whats happening mate :?:
#449
Z1000A2 Z650B1
#69 PostAuthor: paul doran » Fri Jan 20, 2012 2:32 pm
tasty work indeed
sanderz
#70 PostAuthor: sanderz » Wed Jan 25, 2012 1:43 pm
GB & Guyzed - things on hold at the mo.
Wots up DOHC
GUYZED
#71 PostAuthor: GUYZED » Wed Jan 25, 2012 7:47 pm
Thanks for the pm Sanderz and good luck :up
#449
Z1000A2 Z650B1
sanderz
#72 PostAuthor: sanderz » Mon Jun 18, 2012 9:56 pm
Related toon if yer want it -
http://www.youtube.com/watch?v=9yz6Mz-gzLU
Well its been a while. several months since the last 'update' mostly due to ..... just opening the book of excuses here ..... yeh. usual story .... im a lazy fekker - always in the number one slot that one, other than that i aint been around that much, oh an me computer took a life of its own, turning itself off at will :roll: maybe the gas had run out ... or did it just need another 50p in the slot at the back (anyone else have a TV like that back in the day?)
Anyhow back in the modern world again an' having popped in on the Zed gatherin' at Squires for a few hours recently came back with some inspiration to 'do a bit'
Good to put faces to names by the way :up
Soooo with plenty of 'unfinished jobs' on the list or initial ideas that need changing i had a look thro' me scrap box and armed with trusty hacksaw, faithfull drill and a draw of files cobbed bracket for the steering damper out of 3"x2" billet.
Numerous cardboard templates, a lot of cutting and filing, 20 brews, 40 tabs, 10 hours kip, a tickle with some fan grinders an' a dab with the odd spot facer and i had this -
Not wot i'd initially thought it would look like, but hey turned out 'alf right.
Just as well coz i dont want to make another!
Fork clamp is from Streefighter bling, damper is a 'hand me down' Sprint item and the frame clamp is from MPL Germany.
Wots up DOHC
sanderz
#73 PostAuthor: sanderz » Mon Jun 18, 2012 10:06 pm
Next decision was to change the footpegs, even tho' i liked the black rearsets but ...... always a but aint there .....the gearchange was already using a large spacer and the rose joint linkage needed to be reversed (GB pointed this out to me in an earlier post) when i did so the angle increased on the rod and ... well long story short ive changed 'em.
Having had some Spondon pegs donated that were last gracing a YZF endurance bike circa 93-95 thought i'd use them if i cut some 10mm plate.
Que the saw, file, plenty of brews an tabs scenario an i had these -
Wots up DOHC
#74 PostAuthor: Al » Mon Jun 18, 2012 10:10 pm
http://www.youtube.com/watch?v=sV0lKD3KPsc
coldsummer
#75 PostAuthor: coldsummer » Mon Jun 18, 2012 10:18 pm
Nice to see you back sanderz, I've missed you. Looking forward to seeing some more progress.
