As its Reynolds 531 and all brazed construction, they ideally need to be brazed on.
Whats the score with brazing - pro's & cons, easy/difficult, etc...
kev edwards wrote:As Kas says, right solder needed as silver solder comes in various grades correct flux, parts also need to be a very close fit as silver solder has poor gap filling qualities.
Pigford wrote:kev edwards wrote:As Kas says, right solder needed as silver solder comes in various grades correct flux, parts also need to be a very close fit as silver solder has poor gap filling qualities.
So - brazing uses "silver solder" - is it 'one & the same' thing then
Pigford wrote:Cheers for the advice chaps - clear as mud to me![]()
As mentioned the frames were done with brass stuff - so wanna keep it the same
