Harris Magnum 1
RogerJ
#61 PostAuthor: RogerJ » Tue Nov 15, 2011 11:42 am
Looking brilliant, getting some good stuff together, but I am not sure about the new black fuel tank though :roll:
Roger
Ex Fat Rabbit
#62 PostAuthor: Ginger Bear » Tue Nov 15, 2011 2:41 pm
That swinger is a thing of sheer beauty. :drool
Let me know when you're gonna sell it. :bla
# 104
Magnum1
#63 PostAuthor: Magnum1 » Tue Nov 15, 2011 7:17 pm
Have to stop looking at this, makes my screen go all sticky.
Rod
KWACKERZ1
jmc
#64 PostAuthor: KWACKERZ1 » Tue Nov 15, 2011 8:26 pm
Took me bloody ages to source a JMC for mine and you find one in what a week!! :roll: Great stuff. Do you rememebr Ricardos harris that was up for sale a while ago that had a jmc in but an eccentric one.
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/Harris%20Magnums/Harris2wpowers.jpg[/img]
You have got to be tempted to stick your MK2 sprint engine in the HARRIS ?
I think I had better get on with mine and get it finished otherwise you'll put me to shame! Mind you only had mine for 3 years so early days for one of my projects :oops:
#65 PostAuthor: Pigford » Tue Nov 15, 2011 8:38 pm
KWACKERZ1, yes I am considering using the Mk.II motor :twisted:
The JMC is of unknown specification - but it was a bargain & only needs 5mm off each side to fit in the frame, and I much prefer the slotted adjusters as the eccentric's are liable to slip & spin :!:
The 190 tyre is gonna cause me a bit of hassle - but cross that bridge when I get there....... I can go down to a 180 if needs be :|
#66 PostAuthor: Rich » Wed Nov 16, 2011 7:43 pm
Pigford wrote:KWACKERZ1, yes I am considering using the Mk.II motor :??
The 190 tyre is gonna need a lot of power to push it around
:twisted:
debben1
#67 PostAuthor: debben1 » Thu Nov 17, 2011 3:21 pm
Looking good Pigford, more pics please
#68 PostAuthor: Pigford » Fri Nov 18, 2011 8:02 pm
debben1 wrote:Looking good Pigford, more pics please
Thanx Romeo :wink:
Me new wavey disc's turned up & here them is...
I also got an old mag that had a Magnum 1 in it (July 1979) - so thought it may be of interest to some of you ...
#69 PostAuthor: Pigford » Sat Nov 19, 2011 5:33 pm
Had to clean a few bits up on the frame today - there were some old bits of brazing where some lugs had been removed.........
I've got the old lugs ready for "re-attachment" for the lower rear engine mounts, and just need to get it all over to the old chap who's gonna do the job :wink:
#70 PostAuthor: Pigford » Sat Nov 26, 2011 4:55 pm
I've now had the lugs brazed back on and took the frame and swingarm to TALON for an estimate to trim 7mm off each side of the JMC & make a spindle sleeve - as the Harris spindle is 20mm & the needle bearings are 25mm :shock: They said it would be about a days work (setting up the machines takes a while) and £250 max. I could get it done a bit cheaper, but I want this work done right!!!
In the mean time I've made some card board templates of the lower rear engine mounts, to line up with the lugs..... I had some 10mm ally plate which I'll cut out for the brackets.
I also took Mr JigSaw to the Zed Butt unit & hacked a bit of fiberglass off....
The JMC is sitting ON the pivot in those shots and the rear end is sitting rather low.
I'll make some brackets and make surethe seat is nice and firm to support the rider :??
I dropped a few bits off to Mikey on Thursday afternoon and took the cam cover off - so I could get my first glimpse of the motor internals....
..... as luck would have it, the top end looks good, the cams are mint and the clearances are spot on :twisted: As you can also see, the cam caps have the standard bolts fitted - so hopefully no surprises there!
I think I'll be doing the minimal mechanical work and just give it a thorough service, a bit of a clean up and run it :!:
HowieD
#71 PostAuthor: HowieD » Sat Nov 26, 2011 5:41 pm
Pigford wrote:
debben1 wrote:I also got an old mag that had a Magnum 1 in it (July 1979) - so thought it may be of interest to some of you ...
Holy Bat Poop !!
I never knew any other mags had done a road test of "that" bike !!!
The whole reason I have my Harris is because it was featured in April 1980 Bike Mag ! bought My Z1-R just for the engine - I had a plan in them days!!!!
any chance of a better posting of the scans ??
regards
H :lol: wie
Padders
#72 PostAuthor: Padders » Sat Nov 26, 2011 6:52 pm
PM me your details Howie and I will post you the originals. I have a folder with many of the Harris Magnum articles over the last 30 years.
#73 PostAuthor: Pigford » Sat Nov 26, 2011 6:56 pm
Got any good stuff on the Magnum 1 - early 80's :P :?:
andyb1962
#74 PostAuthor: andyb1962 » Sat Nov 26, 2011 7:10 pm
Andy :wink:
#75 PostAuthor: Al » Sat Nov 26, 2011 10:41 pm
Awesome.
