Engine Rebuild 1974 Z1A
DogsbolloxofZ1B
#16 PostAuthor: DogsbolloxofZ1B » Sun Dec 04, 2011 9:01 pm
Cases apart today and crankshaft out. Studs will be done during the week. :D :D
Clutch basket springs all shattered: Was this a drag bike in a previous life :(
Cases apart & crank out ready for Chris Appleby..
Clutch plates all knackered too..
More to follow........ :P
Crofty
#17 PostAuthor: Crofty » Sun Dec 04, 2011 10:02 pm
Keep at it, I like watching this sort of stuff!
pertonpc
#18 PostAuthor: pertonpc » Sun Dec 04, 2011 10:35 pm
Agree with Crofty this is great stuff.
Will the clutch basket get replaced or can you get in to replace the mullered springs - looks like some hefty rivets holding them.
Is there some sort of (rubber?) damper in the basket? could you show a pic if there is. I'm learning lots from this.
From Mark
DogsbolloxofZ1B
#19 PostAuthor: DogsbolloxofZ1B » Mon Dec 05, 2011 12:27 am
pertonpc wrote:Agree with Crofty this is great stuff.
From Mark
The springs can be replaced, again Chris Applybee does this properly :shock:
I've worked on very early '72 bikes and never seen any rubber cush shox but have heard of them being fitted. Any one got any images :?:
The bearing tolerance on this basket is as new so I'll use some German rust treatment to remove & inhibit and it should be fine.
sanderz
Re: Engine Rebuild 1974 Z1A
#20 PostAuthor: sanderz » Mon Dec 05, 2011 10:48 am
Excellant thread this and will be watching as its transformed.
I would of been calling the scrapman at this point :shock: -
DogsbolloxofZ1B wrote:
Clutch basket - had some abuse due to wheelies / drag starts?
Rebuild kits are available for Z9 (Debbens, complete with rivets)
Think the rubber cush shox mentoined are on 650's.
Keep it going :up
Wots up DOHC
Crofty
#21 PostAuthor: Crofty » Mon Dec 05, 2011 11:36 am
True, the 650 have rubber cush blocks in the clutch basket, the 900/1000 had springs.
Rubber is complete PITA! I have yet to find/see a basket on the 650/750 that does not have play in it. Had to rebush mine by sourcing some rubbers that a guy in OZ had made in a batch, then drill apart my basket, replace the bushes and then reassemble, as said PITA. Crofty
DogsbolloxofZ1B
#22 PostAuthor: DogsbolloxofZ1B » Wed Dec 14, 2011 7:11 pm
A few more images showing the tool I use for removing cylinder head studs, if they don't come out with a standard ratchet then its time to use the 3ft breaker bar. I soak these in Release agent for 24 hrs then apply some heat with a blow torch then use the tool. :D :D
Everything is either away being vapour blasted, polished or refurbed so not much more to add until new year.
Mike
eastlondon
#23 PostAuthor: eastlondon » Mon May 07, 2012 8:20 pm
Any chance of an update on the engine rebuild, please?
DogsbolloxofZ1B
#24 PostAuthor: DogsbolloxofZ1B » Tue May 08, 2012 7:58 pm
eastlondon wrote:Any chance of an update on the engine rebuild, please?
Sorry lost track trying to complete my Z1000-A1 and the Z1A engine. Images to follow shortly but it's fully assembled now and looking very sweet given what I was presented with. :D
Mike
DogsbolloxofZ1B
#25 PostAuthor: DogsbolloxofZ1B » Tue May 08, 2012 8:26 pm
Here ya go..
Top crankcase with studs in place:-
Bottom Crankcase prepped:
Selectors in:
Camchain old vs New:
Bits BZP's:
Crank in, chain fitted & cases together:
Prep for barrels:
Some cases fitted:
Head & camcover on:
Finished awaiting collection.
750steve
#26 PostAuthor: 750steve » Tue May 08, 2012 9:01 pm
Holy F dude thats 1 hell of a transformation!!
DogsbolloxofZ1B
#27 PostAuthor: DogsbolloxofZ1B » Wed May 09, 2012 11:47 am
750steve wrote:Holy F dude thats 1 hell of a transformation!!
Thanks, a lot of hard graft went into reclaiming this one froom the dead :D :D
Gyesdad
#28 PostAuthor: Gyesdad » Wed May 09, 2012 4:15 pm
Absolutely amazing! :shock:
Tonto
#29 PostAuthor: Tonto » Wed May 09, 2012 6:38 pm
Dogs - thats a truly gobsmacking transformation.
:clap :clap
zilch
#30 PostAuthor: zilch » Wed May 09, 2012 6:53 pm
Hmmmm let's hope it's more of a success than mine.
