Can anyone recall if the fork tube slides all the way to the bottom of the stanchion:?:
I've got a set of '72 forks on the bench at the moment, stripped all the damper rods etc. When I insert the new tubes they stick approx 100mm from the bottom and both sides are the same. Its been a while but I'm sure they should reach the bottom without being forced. Nothing in the manual either.
I've bought a Silicon carbide honing bar especially for the job but just wondered if anyone else had come across this? The internals look a bit grotty near the bottom maybe water contaminated the oil in the past.
Mike
Z1 Forks
- DogsbolloxofZ1B
- DogsbolloxofZ1B
GEZ635 wrote:I always find non genuine sliders always stick and need a bit of a hone.The trouble when chroming tubes is there is normally more chrome at the ends of the tube. Dont know why this happens buy I have had it lots of times.
It's called dog boning and is because the current density is higher at the contact points when electroplating.
Users browsing this forum: Bing [Bot] and 36 guests
