head bearings
ZED1-18again!!
head bearings
#1 PostAuthor: ZED1-18again!! » Mon Dec 12, 2011 11:07 pm
Hi all, was wondering what advantages taper roller bearings have over stock ball-bearings, when fitted to zeds steering heads?? And how easy to fit them? :)
hanskloss
#2 PostAuthor: hanskloss » Tue Dec 13, 2011 7:44 am
Hi, the advantage is the working surface of a roller is much larger than of a ball so the taper bearing should last much longer, I did mine last year and the job was easy, plenty of sets on the market but not many that have dust seals included, I got AllBalls brand wit the seals, I've heard tapers might be difficult to remove but considering the design there should be no need
DogsbolloxofZ1B
#3 PostAuthor: DogsbolloxofZ1B » Tue Dec 13, 2011 7:23 pm
They are a swine to remove, I think the jury is out on wether they deliver any tangible benefit. :??
If you do fit them, remove the old 1/4" ball cups and using a Dremell grind a small pry point in such that you can get an 8mm dia rod at the right angle to drive the outer races out in the future.
Mike
Crofty
#4 PostAuthor: Crofty » Tue Dec 13, 2011 7:27 pm
Thanks for the tip DB, the races I have taken out in the past were getting replaced, so just tacked a small bar of metal across to tap on from other end.
Like that idea though, guess what i will be doing tomorrow. Crofty
Gavin
#5 PostAuthor: Gavin » Sat Feb 18, 2012 3:56 pm
They are not that easy if in the past a plank has put the upper head bearing in upside down. so i couldn't even use the old outer with new inner race.
There are some dopes about shouldn't be allowed to breed
Z1000 MK2
Z1300 DFI
#6 PostAuthor: PAULJAC47 » Sat Feb 18, 2012 4:05 pm
Doddle to remove old races i use a rounded,flattened steel bar to drift out old races,the ideal way to fit new ones is a set of plastic bearing drifts but a piece of hardwood works ok,i reckon its a very worthwhile mod and have done it on both of my zeds the standard set up is ok for pushbikes :lol:
Gavin
#7 PostAuthor: Gavin » Sat Feb 18, 2012 4:20 pm
PAULJAC47 wrote:Doddle to remove old races i use a rounded,flattened steel bar to drift out old races,the ideal way to fit new ones is a set of plastic bearing drifts but a piece of hardwood works ok,i reckon its a very worthwhile mod and have done it on both of my zeds the standard set up is ok for pushbikes :lol:
If the outer race is upside down there is nothing to put the bar onto.
As the inner race is in situe i am going to use a socket which is slightly narrower than the stock tube
And a Lump hammer
Z1000 MK2
Z1300 DFI
