Where do i begin........i have gotten my Z1R back from having the head sorted out (valves,guides etc) all is well on that side of things.
When i put it in to this guy i said that it had a misfire just off idle when pulling away, he told me that i had the wrong bleed pipes, after this he then broke his foot and could not then test ride the bike for some time to test it out to try and sort out this fault.
So
i agreed to take the bike (as it will be months before he can ride again)
So with his recommendation i bought the correct bleed pipes with rubber seals all excited i fitted them, and hey ho the bike runs like a dream, big improvement all over the rev range..................but! (though it is not as bad) this fookin off idle stutter is still there
I have got standard mains (107.5) and standard pilots (15's) airscrew turned out 1.5 turns, if i set it too 1 1/4 it runs too rich (sooty plugs), the floats are at correct height, carbs are balanced blah blah.
the bike has electronic ignition from a mk2 Z1000 with suitable coils (nice big fat blue sparks), advance retard is working, bike is fitted with a marshal 4-1 exhaust
This problem has existed ever since i bought the bike, and it is driving me effin mad
I dont know what too look at next
Anyone any ideas
Fanx
Desperate in cornwall
Assume carbs are nice & clean & float heights, etc are OK
