Progressive Springs
IrishKev
Progressive Springs
#1 PostAuthor: IrishKev » Wed Jan 18, 2012 11:59 pm
Hi
I was replacing the seals on the front forks of my Z1A. During the strip down I took out the springs and didn't pay any attention to how they came out. On reassembly I noticed that they are progressive springs and at one end of the springs they where slightly more compressed than the opposite end which appear to be more open.
My question is which way are the springs put back into the forks. Compressed end at the top or the bottom or does it matter as long as both springs go back in the same way.
Thanks guys for any help
sweptail
#2 PostAuthor: sweptail » Thu Jan 19, 2012 2:27 am
I would say compressed bit goes at the top.
#3 PostAuthor: Pigford » Thu Jan 19, 2012 8:27 am
Good question - can't see it really matters :|
The proper "racers" won't use them as it complicates handling issues - hard to tune the suspension as you don't know what part of the spring rate is acting or when.
I think they're more of a "placebo" effect. Truth is that when you fit progressive springs, you're replacing very old ones anyway, so even new standard springs would be a revelation :!:
I suppose they're no more (maybe less) expensive than the OE springs, and won't make too much difference either way on an old Zed :P
#4 PostAuthor: kev edwards » Thu Jan 19, 2012 8:49 am
The more compressed end goes upwards, it said in the instructions when i replaced a set, but as piggy says can't see how it matters really.
IrishKev
#5 PostAuthor: IrishKev » Thu Jan 19, 2012 1:14 pm
Thanks Guys for the replies, at least I know now what way they should go in now.
Irishkev
gray
#6 PostAuthor: gray » Sun Jan 29, 2012 11:29 am
The rule of thumb that I heard was that the tighter coils always go to the end which doesn't move-- so you can apply this to fork springs , shocks , valve springs etc
gray
