Z1000A1 modified
PaulMceleney
Chunks
#46 PostAuthor: PaulMceleney » Sun Jan 22, 2012 11:15 pm
can you tell me how you fixed the shocks to the frame cheers
morten
#47 PostAuthor: morten » Tue Jan 24, 2012 11:53 pm
paulmceleney wrote:can you tell me how you fixed the shocks to the frame cheers
I used a set of extenders from PMC. They have two types the one about 15mm longer than the other. Depends on the width of your swingarm wich one to use. i used the widest ones.
Then you just have to make two 14mm holes in the frame at the position you will have them and then weld them from both sides. easy match.
The parts i think you can order from Z-power and they do not cost much.
Any questions please ask. Cheers
garyd
#48 PostAuthor: garyd » Wed Jan 25, 2012 10:33 am
Hi Morton,
When you say extenders...are they origionally intended just to fit over the existing mounting points?
i was going to get some turned up for me but If I can but a set over the counter it would maake life a lot easier.
thanks
KWACKERZ1
#49 PostAuthor: KWACKERZ1 » Wed Jan 25, 2012 1:18 pm
Gary,
I think these pmc ones replace the originals which is why you have to drill and weld the frame.
They dont fit over the existing ones.
garyd
#50 PostAuthor: garyd » Wed Jan 25, 2012 4:50 pm
Ah...thought it was too good to be true.
Iain marshall
#51 PostAuthor: Iain marshall » Wed Jan 25, 2012 6:26 pm
Gary, ones like this you're talking about?
Adaptor used to move top shock mount out on your old Zed when fitting a slightly wider swing arm, think the spacer is 14mm, about as much as you would want to go with this set up
garyd
#52 PostAuthor: garyd » Wed Jan 25, 2012 8:02 pm
Yeah..that's them.
So did you make them yourself or are they available to buy somewhere?
PaulMceleney
Chunks
#53 PostAuthor: PaulMceleney » Wed Jan 25, 2012 8:13 pm
Thanks for taking time to answer my question
morten
#54 PostAuthor: morten » Wed Jan 25, 2012 10:54 pm
garyd wrote:Hi Morton,
thanks
Gary, what I mean is the extension in width between the schock absorbers when using a wider swingarm compared to the standard one.
That is one of the reason (together with drivability and look) to move it forward on the frame also, because the frame is wider and you do not have to make too long schock fastening arms.
If you are going to use 5.5" or 6" rims and a 190 tire you need a real wide swingarm and extend the chock fastening points to get the schocks in paralell horizontal. Hope you understand what I mean, and you have to excuse my bad english :oops: Cheers
morten
#55 PostAuthor: morten » Mon Apr 23, 2012 8:56 pm
Did do a Dynorun on the bike yesterday and promised TLC to take a video.. here it is. :)
The Dyna 2000 ignition burned up during the first run so I have nothing to print yet. Will come back to the curve later when fixed.. The video speak for itself doe :fire2
I think is running a little to rich now and will rejet it until next try :twisted:
#56 PostAuthor: Pigford » Mon Apr 23, 2012 9:10 pm
Sounds wicked :twisted:
I'm on a replacement Dyna 2000 - but luckily Dynatek replaced my control box free of charge - that was a few years ago & it's been fine since - now most of their stuff's made in China :??
morten
#57 PostAuthor: morten » Mon Apr 23, 2012 9:28 pm
Pigford wrote:Sounds wicked :twisted:
I have heard that a lot of guys have their 2000 boxes replaced :|
Will try to write Dyna a mail and hear what they have to say, if there is problems I will switch to the PSII ignition simular to the one I have on my ZRX
tlc
#58 PostAuthor: tlc » Mon Apr 23, 2012 9:42 pm
Sounds sooper dooper Morten.
I particularly like the spitting flames. Like a Norwegian dragon :shock:
Bill Newman
#59 PostAuthor: Bill Newman » Mon Apr 23, 2012 10:40 pm
I really like that
#60 PostAuthor: Pigford » Tue Apr 24, 2012 6:45 am
Need more info on the PSII ignition - is that PLAYSTATION? :lol:
Users browsing this forum: No registered users and 163 guests
