trick z1000
KWACKERZ1
#676 PostAuthor: KWACKERZ1 » Fri Jan 27, 2012 9:20 am
Brian,
I have some zrx shocks that i have been saving for a project, not sure where they are but I know they are longer than my std z1000 ones.
I'll try and find them over the weekend and give you some dimensions.
KWACKERZ1
shocks
#677 PostAuthor: KWACKERZ1 » Fri Jan 27, 2012 10:01 am
Just remembered where they are:
so here we go
length eye to eye, 360mm top eye diameter 14mm 20mm depth bottom eye 10mm 20mm depth. (the actual bush external diameters are 25mm )
See pics, if you need anything else let me know.
Phil
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/pb2004.jpg[/img]
[/img]Image
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/pb2006.jpg[/img][/img][/url]
brian 450
#678 PostAuthor: brian 450 » Fri Jan 27, 2012 10:20 am
Phil, Thanks for taking the time to do that it is very helpful. Brian
brian 450
#679 PostAuthor: brian 450 » Fri Jan 27, 2012 5:55 pm
I have made the new top shock mounts and drilled one side of the frame out. I might try and weld it tommorow. The problem is i think i will be a bit rusty at welding as i have not done any since i braced the frame. :roll:
Taffus
#680 PostAuthor: Taffus » Fri Jan 27, 2012 9:02 pm
brian 450 wrote:I have made the new top shock mounts and drilled one side of the frame out. I might try and weld it tommorow. The problem is i think i will be a bit rusty at welding as i have not done any since i braced the frame. :roll:
practice, practice, practice.....
There must be someone with a GS1000 near you rusting in pieces! :D
brian 450
#681 PostAuthor: brian 450 » Sun Jan 29, 2012 6:21 pm
Been busy this weekend doing the new shock mounts. I think it is a lot better now
brian 450
#682 PostAuthor: brian 450 » Sun Jan 29, 2012 6:22 pm
Padders
#683 PostAuthor: Padders » Sun Jan 29, 2012 6:30 pm
Looks good Brian
#684 PostAuthor: Ginger Bear » Sun Jan 29, 2012 6:57 pm
100 x better Brian.
We've got a lot to thank these Norwegians for. :roll: :lol:
# 104
ukcoupe
#685 PostAuthor: ukcoupe » Sun Jan 29, 2012 7:06 pm
That looks perfect now. Top job!
PaulMceleney
Chunks
#686 PostAuthor: PaulMceleney » Sun Jan 29, 2012 7:51 pm
looks much better
KWACKERZ1
#687 PostAuthor: KWACKERZ1 » Wed Feb 15, 2012 1:52 pm
Brian,
Looks very good.
Any chance of a drawing of the shock mounts as I want to move some and it will save the time to draw some up for my fabricators to get some made.
Cheers Phil
brian 450
#688 PostAuthor: brian 450 » Thu Feb 16, 2012 8:03 pm
Will do as soon as I am fit laid up with bloody flu at the mo.
KWACKERZ1
#689 PostAuthor: KWACKERZ1 » Fri Feb 17, 2012 9:28 am
Cheers , and hope you get better soon.
A mate of mine has been really bad and off work this week with the flu, but his gs1000 is coming on well! :lol:
brian 450
#690 PostAuthor: brian 450 » Tue Feb 21, 2012 7:26 pm
Got these little beauty's today. :hoo
