Harris Magnum 1
#121 PostAuthor: Ginger Bear » Fri Feb 10, 2012 6:22 pm
Pigford wrote:
Following weekend on a short break to Brixham (Devon) for Valentines :lol:
You old romantic Piggy. :lan
# 104
#122 PostAuthor: paul doran » Fri Feb 10, 2012 7:00 pm
Heprobably got the Weekend for free :lol: :lol:
#123 PostAuthor: Pigford » Wed Feb 15, 2012 5:15 pm
I finally got round to drilling out the broken/rusted bolt remains & re-tapping - this is to hold the side stand kaboodal :|
Next is fitting the brakes.... I've gone thru' a few options, this being one that I've now rejected.....
It's a proper MICRON adaptor - converts the forks to use common Nissin 4-pots, etc.
I'm gonna use the lower caliper mount as a direct fit - just need 5mm shaved off the inside to align it - then make a small adaptor lug out of 10mm alloy plate, then JOB DONE :P I had wanted to get a new lug welded on, but the chap reckons alloy fork sliders will most likely deform/shrink if welded and the fork action may suffer
KWACKERZ1
#124 PostAuthor: KWACKERZ1 » Wed Feb 15, 2012 5:31 pm
LOOKS CRAP!!
Just give me the calipers you know it makes sense :lol: :lol: :lol: :lol:
Will get them measurements done tonight sorry for the delay, but my stripped frame and swing arm have been at the powder coaters!!
MCZ900
#125 PostAuthor: MCZ900 » Wed Feb 15, 2012 10:58 pm
Nice, very nice
:D
1973 Z1 and 1976 Z900
KWACKERZ1
DIMESIONS
#126 PostAuthor: KWACKERZ1 » Thu Feb 16, 2012 10:07 am
Hopefully this will be some help for you.
Of the two shocks I have the HYPERPRO is 280mm eye to eye with a 70mm travel and a hyperpro 0467 spring?
The standard harris de carbon is 270mm with 60mm travel.
On the red pict below
A=The swing arm is 430mm pivot to wheel spindle centre.
D=385 from wheel spindle centre to shock mount center and E= 215mm from the shock mount to swing arm pivot centre.
C= The wheel spindle centre sits vertically at a height of 460mm to the top frame tube (the gap with a 17â€￾ wheel and tyre is 6inches)
B= The total length from the shock mount on the frame to the wheel spindle centre is 615mm.
Bear in mind these are measured with a tape measure so may vary 1-2mm.
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/harrisdimensions.jpg[/img]
[/img]Image
#127 PostAuthor: Pigford » Thu Feb 16, 2012 1:49 pm
Cheers Phil - top job :wink:
KWACKERZ1
spring
#128 PostAuthor: KWACKERZ1 » Fri Feb 17, 2012 3:25 pm
Piggy,
Just had a message back from HYPERPRO as I enquired what the spring rate was for the Harris unit and this is what they sent.
Hello Phil,
It runs from 160 to 240 n/mm
Since it has quite a range, you should actually be fine if you adjust the spring pre-load
Regards,
J.troost
Hyperpro
Thought the info may be of use for your shock setup
#129 PostAuthor: Rich » Fri Feb 17, 2012 6:20 pm
My WP is 80nm
#130 PostAuthor: Pigford » Wed Apr 04, 2012 7:09 pm
Did a bit to the front calipers..... Ended up trimming approx 2mm off each lower fork lug, then spent an hour hand filing them flat & square to align the calipers square to the discs :!:
As can be seen, the amount relative to the thickness of the lug s minimal. Next I have to make the top bracket..... The mudguard lugs are in the correct place, but only have 5mm bolts - although they are in pairs :|
#131 PostAuthor: paul doran » Wed Apr 04, 2012 7:27 pm
are You sure You have not made a big mistake Piglet
fitting two calipers :lol: :lol:
#132 PostAuthor: Pigford » Wed Apr 04, 2012 7:33 pm
Paully - Its OK, I'll only be 1/2 filling the brake reservoir :wink:
#133 PostAuthor: Ginger Bear » Wed Apr 04, 2012 8:23 pm
Look's like you've been doing this at work Piggy........
.............. Is that so you can get a bit more bike fettling tima past Mrs P at home :?
I can just imagine the conversation........ "Mrs P, I've had a bugger of a day at work, I'm just gonna spend an 'hour' in the garage to 'wind down'. :roll:
:rir :rir
# 104
#134 PostAuthor: Pigford » Wed Apr 04, 2012 9:14 pm
.....you know me too well Mr Bear :wink:
#135 PostAuthor: Rich » Thu Apr 05, 2012 4:22 pm
Ginger Bear wrote:Look's like you've been doing this at work Piggy........
:rir :rir
He's charging the overtime as well :wink:
