main parts are the triple trees and swing arm.Which has held things up a bit.
But i have now fitted the cams and done the timing.So engine is now complete.
In readiness for the swing arm i have refurbished the shocks.
after pics below
I also did a bit of detailing on the rear wheel
Im sure im like most of you when you get new parts.You want to see them on the bike ASAP.
Im replacing all screws with stainless cap heads.I brought standard 12mm fixings and forgot they are fine threads so have fitted the swing arm and mocked up the the rear end.
And then rear wheel and brake
