1980 KZ1000G Z1 Classic
42653steve
#1 PostAuthor: 42653steve » Sun Mar 04, 2012 9:26 pm
I bought this bike as is. I have no spark. Is their a common part that goes bad on these. Where is the best place to start. Thanks for help.
#2 PostAuthor: z1bman » Sun Mar 04, 2012 10:30 pm
does it have a side stand switch + have you got 12v at the coils
Dark Skies
#3 PostAuthor: Dark Skies » Mon Mar 05, 2012 3:09 am
I had the Z1000 H which I think is similar to the G. As I recall it had a ballast resistor slung between the coils - that played up once or twice causing similar problems. Worth checking the connections there as a matter of course.
KZ1000-M1 CSR
#4 PostAuthor: Al » Mon Mar 05, 2012 7:39 pm
From what i've seen the double relay under the LH side panel is suspect and the connectors to the airflow meter and brain need close scrutiny.
#5 PostAuthor: chrisu » Mon Mar 05, 2012 9:50 pm
I too have an H and pretty much everything electrical is suspect.
PM me and I'll send you an H troubleshooting guide in pdf format.
42653steve
1980 KZ1000G Classic
#6 PostAuthor: 42653steve » Mon Mar 05, 2012 11:47 pm
Thanks for all the help. I will post when I get it running.
