Part numbers
Keefleaf
Part numbers
#1 PostAuthor: Keefleaf » Thu Mar 15, 2012 8:59 pm
I've dug out a couple of air boxes .1box has lid,both have KHI DGM 31311s moulded in. The other has KHI DGM 30386s.
I've also got KHI DGM 313115?
How do I find out which model they're from?
steve bowdler
#2 PostAuthor: steve bowdler » Thu Mar 15, 2012 9:18 pm
Keefleaf
#3 PostAuthor: Keefleaf » Thu Mar 15, 2012 9:43 pm
:up Cheers Dude. :wink:
Z903
#4 PostAuthor: Z903 » Fri Mar 16, 2012 8:55 am
Pretty sure you'd need to check more than just the lid? lids will interchange between the 2 air box shapes.
The early Z1000 is just a tad different in it's height compared to the A4 unit.(2 different element heights) If you use the Z1000 in an A4 the snorkel will foul the top of the battery.
