Brake Calipers - what they from originally?
martinz1000r
#1 PostAuthor: martinz1000r » Wed Mar 21, 2012 12:14 pm
Brake calipers from my Z900. Need refurb and new pads as seized but what was the original donor bike? Dont want to order the wrong stuff!!
tricky
#2 PostAuthor: tricky » Wed Mar 21, 2012 1:11 pm
they look like gsxr/ bandit calipers to me, hope this helps tricky
martinz1000r
#3 PostAuthor: martinz1000r » Wed Mar 21, 2012 1:19 pm
that's what i was thinking but were they not Nissin on Suzukis? I was wondered ZXR750?
steve bowdler
#4 PostAuthor: steve bowdler » Wed Mar 21, 2012 1:44 pm
These were on Suzuki and Kawasaki , not much help :??
#5 PostAuthor: z1bman » Wed Mar 21, 2012 10:39 pm
andy c
brakes
#6 PostAuthor: andy c » Thu Mar 22, 2012 8:14 am
Looks like a pair Ive got in the loft, that ive done up ready for a project that never came off. The bodys are fine glass blasted, stainless bolts fitted, all pistons and seals ok and bores ok. Price up yours to rebuild but if pistons/bores are pitted I have the pair for sale.PM me your Email and i will send photo/price if you get stuck . Mine may be a chearer option, and ready to go. By the way I think they are suzuki GSXR 750/1100
steve.w
#7 PostAuthor: steve.w » Thu Mar 22, 2012 8:32 am
rgv 250 :D
KWACKERZ1
#8 PostAuthor: KWACKERZ1 » Thu Mar 22, 2012 9:10 am
GSXR 750/1100 FOUR POTS are Nissin ones, Not tokico.
I have a vague recollection that they are the same though if you want to confirm the piston diameters I'll happily check a set of NISSINS I have for you.
But I think as above RGV250 IS A Likely bet
martinz1000r
#9 PostAuthor: martinz1000r » Thu Mar 22, 2012 10:16 am
i found a few that look similar on eBay but enquiring some are 60mm between centres on the mounts. These are 90mm. The 400cc and below appear to be all 60mm mounts.
Andy C - pm sent.
KWACKERZ1
calipers
#10 PostAuthor: KWACKERZ1 » Thu Mar 22, 2012 12:03 pm
Have a look at.
http://forum.oldskoolsuzuki.info/cgi-bi ... 1294050573
tl 1000s tl1000r hayabusa are all 90mm spacing. But I think tl1000 are six pots but not sure about all models. srad 600 calipers are four pots.
But I think that your calipers could actually be GSXR750Y year 2000 calipers as they have a front piston larger than the rear.
Speak to Gareth at Redcar motorcycles 2 Redcar Road Leicester Leicestershire LE4 6PD. Tel: 0116 266 1637. Fax: 0116 266 2498 www.redcarmotorcycles.co.uk
and he will put you right on what bits you need.
andy c
brakes
#11 PostAuthor: andy c » Thu Mar 22, 2012 4:34 pm
Check your email , sorted em out. Andy
#12 PostAuthor: Pigford » Thu Mar 22, 2012 5:16 pm
Those anodised alloy banjos & bits are an MOT fail - a bit dodgy as they can fracture :!:
MCZ900
#13 PostAuthor: MCZ900 » Thu Mar 22, 2012 5:25 pm
These are also 90mm :D
1973 Z1 and 1976 Z900
#14 PostAuthor: Rich » Thu Mar 22, 2012 6:07 pm
RGV as above, Nissin 4 pots will fit and are better alloy. Alloy banjos also corrode from inside with stainless braid.
