Taco cable
MCZ900
Taco cable
#1 PostAuthor: MCZ900 » Sun Mar 25, 2012 7:42 am
Anyone have the same problem as me, the blumin taco/ rev counter cable unscrewing it's self fro the front of the engine on a long run, that's 2times iv burned my fingers doing it back up lol,
Thanks Ian
1973 Z1 and 1976 Z900
hanskloss
#2 PostAuthor: hanskloss » Sun Mar 25, 2012 8:12 am
try loctite on the thread
mikey
#3 PostAuthor: mikey » Sun Mar 25, 2012 9:07 am
2nd that, mine used to do it untill i put loctite on it
MCZ900
#4 PostAuthor: MCZ900 » Sun Mar 25, 2012 4:34 pm
Thanks chaps, glue time it is then.
Cheers Ian
Z1B Alan
#5 PostAuthor: Z1B Alan » Sun Mar 25, 2012 6:51 pm
MCZ900 I am also a victim of said tacho cable problem however I was also unlucky enough to have the inner cable fall out whilst on the move. As suggested a touch of locktight and no further issues 3 years on.
#6 PostAuthor: Rich » Sun Mar 25, 2012 7:20 pm
put a fibre washer in there and do it up with a pair of pliers
CAT3
#7 PostAuthor: CAT3 » Mon Mar 26, 2012 9:49 am
I used a bit of locking wire wrapped round the bracket & cable, just behind the locking ring.
I figured locktite might go soft when the engine got hot, but it obviously works fine.
MCZ900
#8 PostAuthor: MCZ900 » Mon Mar 26, 2012 12:02 pm
Thanks everyone glued it on last night and i will see how it goes.
