Clocks from Z750 Twin
FreddaAbborre
- Regular Poster
Can I use clocks from a Z750 twin on my Zed? The max limit is 220km/h and 10krmp. Is the angle of the needle the same; so I can use new faces showing 240/12krpm?
Z1 Moto Martin
Z1A
Z1000 A2
Husaberg FE350
Z1A
Z1000 A2
Husaberg FE350
Re: Clocks from Z750 Twin
FreddaAbborre wrote:Can I use clocks from a Z750 twin on my Zed? The max limit is 220km/h and 10krmp. Is the angle of the needle the same; so I can use new faces showing 240/12krpm?
Post a pic and either I or Al Marshall can tell you.
Will.
FreddaAbborre
- Regular Poster
Big Fluff wrote:FreddaAbborre wrote:Can I use clocks from a Z750 twin on my Zed? The max limit is 220km/h and 10krmp. Is the angle of the needle the same; so I can use new faces showing 240/12krpm?
Will.
Here's a pic. Not the best one, havn't bought the clocks yet.
Z1 Moto Martin
Z1A
Z1000 A2
Husaberg FE350
Z1A
Z1000 A2
Husaberg FE350
The speedo (same as Z650) will be fine, and I can provide you with a MPH dial kit to go over the top of the KMH faces.
The rev-counter should be okay as I believe it's the cam gear ratio that's different on the Z750 twin head. i.e. although Z1 to Z1000A2 rev-counter faces read up to a max of 12000rpm, it should still read correct, but ending earlier at the 10000rpm.
will.
will.
FreddaAbborre
- Regular Poster
Big Fluff wrote:The speedo (same as Z650) will be fine, and I can provide you with a MPH dial kit to go over the top of the KMH faces.
will.
But are the clocks basically the same as clocks for Zeds, but with lower max-gradings?
I'm in Sweden so I would change the faces (10krpm/220km/h) to faces for Z1 (12krpm/240Km/h).
Z1 Moto Martin
Z1A
Z1000 A2
Husaberg FE350
Z1A
Z1000 A2
Husaberg FE350
Users browsing this forum: bedlow1 and 62 guests
