ZX9R USD Forks
RUDDY
ZX9R USD Forks
#1 PostAuthor: RUDDY » Sun Apr 01, 2012 11:13 am
Guys, ZX9R-B usd forks and yoke, are these a potential option for Z1000R, whats the fork length like ?
Ebay is a dangerous place for putting ideas in your head.
All the best, Paul
#2 PostAuthor: Ginger Bear » Sun Apr 01, 2012 11:56 am
I've got ZX9R-B3/4 forks on this. Fitted with standard 9R bottom yoke & ZX7R top yoke (7R yoke sits lower than the 9R pushing the forks slightly lower down)
Stansions will probably need re-chroming. I found there was no real cost difference having the re-chromed or buying replacement stantions from Wemoto.
Hard Chrome Plating & Grinding will remove the lower feet for you if you opt for re-chroming.
From memory they're around 770mm from top to the centre of the spindle. I'll whip me tape out later & double check for you.
# 104
garyd
#3 PostAuthor: garyd » Mon Apr 02, 2012 11:02 am
Is that a ZX9 swinger in there as well?
Did you have to machine it to get it in?
#4 PostAuthor: Ginger Bear » Tue Apr 03, 2012 7:52 am
Gary, Swinger is Suzuki GSXR600 SRAD, pretty much goes straight in, you just need to sleeve the pivot spindle. I think tlc discovered that the SRAD spindle has the correct id, to suit the od of your Zed spindle, making it a really easy job.
# 104
Users browsing this forum: bedlow1 and 65 guests
