Throttle return
Throttle return
Just failed an mot due to throttle not returning quick enough. Made what I thought to be the appropriate adjustments to the cables and when the engines off all works well. When the engines running the throttle is very slow in shutting back down. I,m absolutely at a loss. Anyone got any ideas?
						- PETER KZ1A
THanks for the advice chaps. Problem sorted. When I started this project three years ago I promised myself that I'd only use nos or refurbed parts where poss. I've just fitted a bed spring as a replacement for the carb return as the original was too weak. Works a treat. Finally got my mot at 1730 which means I'll make it to the Berkshire meet tomorrow. Guy might not thank you though.
						- steve bowdler
