z900 z650 ,z1000 front mount brake caliper body
ade woollams
#1 PostAuthor: ade woollams » Sun Apr 15, 2012 7:05 pm
z900 z650 ,z1000 front mount brake caliper body wanted threads and nipple ok.its for my kh think all the bodies are the same .
Steve Cooke
#2 PostAuthor: Steve Cooke » Sun Apr 15, 2012 9:19 pm
There are differences such as the bleed nipple position, Z900 nipple is central Z1000 is to the side, I have one (body only) which I think is A1 with the nipple to the left when looking at it which I think is in good condition but I'd have to check, if that's any good you can have it for the postage. I think they'd all work just depends how fussy you want to be.
ade woollams
#3 PostAuthor: ade woollams » Mon Apr 16, 2012 5:39 am
thanks steve.if your bleed nipple is either right or left it will be an a2 behind the forks .i need front mount ,bleed nipples then are all in the centre .thanks for the offer.
Steve Cooke
#4 PostAuthor: Steve Cooke » Mon Apr 16, 2012 10:36 pm
Yes your right Ade, I had a good look around and did find one but it's knackered, hope you find one.
pertonpc
#5 PostAuthor: pertonpc » Tue Apr 17, 2012 12:48 pm
Hi Ade
Try DK bikes in Newcastle (Staffs) or this ebay seller for your caliper mate.
http://myworld.ebay.co.uk/jdcs42/?_trksid=p4340.l2559
Cheers from Mark
tlc
#6 PostAuthor: tlc » Tue Apr 17, 2012 3:31 pm
I may have one.
Can you be patient until the weekend and I`ll have a look.
andy c
caliper body
#7 PostAuthor: andy c » Tue Apr 17, 2012 6:45 pm
Ade. found this one the threads are ok but the body has a bit of road rash
Will it do ? Andy C.
