Z900 A4 Carb refurbishment service
Phil50
#1 PostAuthor: Phil50 » Sun Apr 29, 2012 4:22 pm
Hi All,
Does anyone know a competent company or individual who can sort out my 26mm Mikuni carbs for the Z900.
They work except they dump fuel into pots 1 and 4 and the bike is difficult to control at under 3000rpm its very juddery.
All the jets have been replaced and they have been cleaned ultrasonically.
The bike was restored last year and the carbs floats, and settings set up correctly I am told
The problem persists. I am using a set of Z1000 carbs at the moment so its ridable but would like the correct carbs on the bike before sale.
thanks all
Phil
wayno
#2 PostAuthor: wayno » Sun Apr 29, 2012 5:12 pm
there will be a number of peeps used different services, i used gez635 and will be using again in the not too distant future.
tlc
#3 PostAuthor: tlc » Sun Apr 29, 2012 5:28 pm
Wayno. Didn't he do a proper job the first time ? :roll:
tlc
#4 PostAuthor: tlc » Sun Apr 29, 2012 5:29 pm
Phil50
Gez has a very good reputation.
PaulMceleney
Chunks
#5 PostAuthor: PaulMceleney » Sun Apr 29, 2012 5:35 pm
IF you ment air fillter pods ,if your filter are dirty this will cause this problem or the same with the air box filter replace with new or may be try and clean them
wayno
#6 PostAuthor: wayno » Sun Apr 29, 2012 6:52 pm
tlc wrote:Wayno. Didn't he do a proper job the first time ? :roll:
last time it was a set of 1000a1 carbs next time its a set of900a4's for a full resto :D
RAYZ1
Re: Z900 A4 Carb refurbishment service
#7 PostAuthor: RAYZ1 » Sun Apr 29, 2012 9:44 pm
Phil50 wrote:Hi All,
Does anyone know a competent company or individual who can sort out my 26mm Mikuni ..
thanks all
Phil
I had a problem on No3 on a z1. Took a while to sort out, gez eventually found the problem which I had suspected - a possible hairline crack in the body. The carbs had been cleaned ultrasonically but suspected in too strong a soloutiuon which caused a hairline crack, flooding when hot. ultrasonic cleaning can also dislodge the brass plugs in the carb, so it can cause problems. No 3 had to be replaced.
Check to see the choke system is shutting off ok, the fuel level is set correctly and the floats/valves arent damaged,the jets are firmly seated and not loose, obviusly if the carbs are flooding petrol at standstill then its the floats/valve issue.
