battery not charging
michael thomas
#1 PostAuthor: michael thomas » Tue Jun 26, 2007 6:00 pm
:? I have a problem with the charging system on my z1 ltd the battery seems to go flat after about 1 weeks use i have checked the stator and that seems ok ie continuity between all the coils and no continuity to earth but with the bike running and measuring the voltage on the yellow leads coming from the stator i have 55 volts on two pairs and 20 on the other pair is this a problem with the stator or the rotor, any ideas
#2 PostAuthor: Rich » Tue Jun 26, 2007 8:44 pm
Go here
http://www.electrosport.com/electrospor ... nding.html
download pdf it will tell you everything you want to know to check it out
Users browsing this forum: Headspinning and 107 guests
