Fork identification[MORE HELP PLEASE]
Z1parR
#16 PostAuthor: Z1parR » Sun Feb 12, 2012 7:10 pm
As Rob says all the tubes are 36mm diameter , however Z1R/A2 fork tubes although still 36 diameter are different to all the others - Z1 to Z1000A1 .
0172 . Geoff Parr
zman
#17 PostAuthor: zman » Tue May 08, 2012 9:12 am
im want to check oil level.am i correct that they are 650 forks :?:
can any one tell me oil level and what oil to use :?:
keep thoses wheels turning
Re: ========
#18 PostAuthor: zed1015 » Tue May 08, 2012 9:56 am
zman wrote:im want to check oil level.am i correct that they are 650 forks :?:
Look at the fork bush under the fork oil seal.
If there's a wire circlip they are Z650.
If no circlip they are Z1R.
The 650's chrome stanctions are also shorter.
So probably easier to measure the length from the spindle center to the fork top to confirm which they are.
Users browsing this forum: Bing [Bot] and 44 guests
