ignition timing Z1A
nealblath
ignition timing Z1A
#1 PostAuthor: nealblath » Sat May 19, 2012 11:06 pm
just set my ignition timing using the bulb method and the only way I could get the bulb to light up on the F mark on both sets of points was to have the main backplate advanced as far as possible (anticlockwise) and then each of the points backplate advanced (anticlockwise again) to the end of their slots!
checked the T marks and and pistons at TDC where they should be!
have got the bulbs to light on 1+4, and 2+3 on their F marks but should I have everything so advanced?
skibs
#2 PostAuthor: skibs » Sun May 20, 2012 8:02 am
try checking the condition of the points & gap.worn or pitted points can easily throw them.also tight gap will retard timing,wide will advance.
just for reference,adjust gap on one set of points & recheck timing for those cyls.suprising what difference it makes.
nealblath
#3 PostAuthor: nealblath » Sun May 20, 2012 8:15 am
skibs wrote:try checking the condition of the points & gap.worn or pitted points can easily throw them.also tight gap will retard timing,wide will advance.
they're brand new points skibs, gaps set at 0.35mm
just wondering if the advance/retard mechanism is faulty.......but then TDC would surely be wrong and it's spot on
#4 PostAuthor: z1bman » Sun May 20, 2012 8:33 am
had the very same problem last year
Posted: Sat Aug 13, 2011 7:04 pm Post subject:
ok so i spent nearly 2 days at my friends earlier this week trying to sort this ignition problem. we replaced the complete back plate assembly with a genuine Kawasaki part. we fitted the back plate checked the points gap without adjusting anything . points gap was 14 thou. started the bike checked the timing with strobe light. timing was 10degrees out tried to adjust by turning the back plate + could only get it to fire 5 degrees before the F mark without elongating the holes in the back plate there was no other way of getting it to fire in the right position. we did try filing the heel of the points bit by bit until there was virtually no heel left on the points . this did absolutely nothing. we checked the advancer marks in relation to TDC+ this was spot on. after a lot of working things out i have come the the conclusion that the the problem is with the advancer cam. this is in the wrong position when fitted to the advancer shaft. the 2 slots which are machined into the cam were the advancer bob weights are located have been machined in the wrong place. this is why so many people are running theirs with elongated holes in the back plate + running with an excessively wide points gap
Back to top
zman
#5 PostAuthor: zman » Sun May 20, 2012 8:38 am
DYNA S
Fit it and forget it :lol: :lol:
keep thoses wheels turning
nealblath
#6 PostAuthor: nealblath » Sun May 20, 2012 11:46 am
just fired it up for first time in 10 years. Fired up first push of button and it runs sweet as a nut even though plate is advanced so I'll leave it. Thanks for the replies guys :D
