z1b handle bar options
Big John
#16 PostAuthor: Big John » Sat May 26, 2012 8:14 am
scott wrote:Big John......i'd rather ride at 100mph with slightly raised flat bars than standard cowhorns.......feels less windy.....and feels like you have more control/weight over the front end.......not as good in very slow traffic to cowhorns though
I agree the lower bars are better than the higher bars , the bike handles better too, stock risers with Renthal superbike lows are IMO the best way to go.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
Bongoball
#17 PostAuthor: Bongoball » Sat May 26, 2012 9:09 am
Hi Bob,
Check out the Renthal Fatbars on Brian450 rebuild...
http://www.z1ownersclub.co.uk/forum/vie ... &start=705
Is this the look you're after?
Bongo.
"Keep on Rockin'!"
bob fell
#18 PostAuthor: bob fell » Thu May 31, 2012 2:08 pm
There is a company on ebay that do a multi stage bar riser kit, I just need to measure the diameter of the bars before I order as they do two sizes.. 25mm and 22mm bars,I think it will be 22 mm is that 7/8?? I do like the look of the Renthal fatbars
Bob
#19 PostAuthor: Ginger Bear » Thu May 31, 2012 3:06 pm
I know it's a vid, (click the pic) but it does picture Renthal FatBars & Renthal Risers.
# 104
#20 PostAuthor: Ginger Bear » Thu May 31, 2012 3:10 pm
You could probably use something like these, if you want to use your original top yoke.
http://www.ebay.co.uk/itm/Motorcycle-Mo ... 646wt_1265
# 104
#21 PostAuthor: ADRIAN H » Thu May 31, 2012 5:36 pm
My z1000a2 with almost flat bars, no risers.
000zeds
#22 PostAuthor: 000zeds » Thu May 31, 2012 6:48 pm
Adrian is that a Z1000MK2 cylinder head :?:
Zeds-R-Us
#23 PostAuthor: Ginger Bear » Thu May 31, 2012 6:58 pm
Looks like a 'J' or GPz head & barrels to me, but then living that close to Debbens it would be almost rude not too! :roll:
# 104
#24 PostAuthor: ADRIAN H » Thu May 31, 2012 7:07 pm
twozeds wrote:Adrian is that a Z1000MK2 cylinder head :?:
Z1000J head, with APE cam chain top idler conversion, Webb cams.
Engine has recently had a full engine rebuild including full cylinder head refurbishment by Steve and Ray at - DEBBENS PERFORMANCE , who do a very good jod. Keep meaning to do a thread in the projects section. Tommorrow I will be fitting a hydraulic clutch I bought from germany.
bob fell
#25 PostAuthor: bob fell » Sat Jun 02, 2012 11:30 am
hope the pick works im not good with photobucket, any opinions on type of bars and risers? the bikes I have seen seem to have beefed up front ends
