Wots Cooking
sanderz
#76 PostAuthor: sanderz » Mon Jun 18, 2012 10:25 pm
After staring at the back end (an unusual hobby that has landed me in trouble more than once)
Rear light was next for alterations (the numberplate bracket just didnt do it for me before, oh, and im thinking of having the plate on the stainless gaurd - between the upward frame rails, theres a row of 4mm bolts but coz of legalities its a maybe :roll: )
Boxed in using alloy plate folded, then some 20mm square blocks riveted in with tapped 6mm holes in. Covered it in sticky back plastic (3M carbon look)
Countersunk washers are from a Karting shop - cheapest i could find :wink:
Wots up DOHC
sanderz
#77 PostAuthor: sanderz » Mon Jun 18, 2012 10:33 pm
zorded wrote:
Not wot i'd initially thought it would look like, but hey turned out 'alf right.
http://www.youtube.com/watch?v=sV0lKD3KPsc
Alrighty Al
Ha ha made me laugh that, nice one
Ay up Coldsummer!
Hmm seems i cant use the emoticons at the mo, ah well
Wots up DOHC
sanderz
#78 PostAuthor: sanderz » Mon Jun 18, 2012 11:09 pm
If i was a bit more shall we say 'conversant' with this keyboard malarky and photobucket oh an Youtoob i probably could have posted this in one shot but ... see theres that 'but' again .... well i aint ha ha
Anyhow, by now i was ready to put a battery on - a new un, one of them sealed batterys. Connected it up and .....
Nothing, check thro' and seems at the centre loom id connected blue to blue (Alt) Green to green (Rect/Reg combo) oh and white to white - new repo loom has a white plug that when looking around this forum should fit onto the Brown plug - nob!! So changed itround and -
Spun it over several times with the plugs out to circulate the oil, plugs were sparking by the way. Put plugs in, added fresh fuel to the remote tank -
and ..... Nothing!!
Not a pop, fart or hiss ... ah well.
Plugs out - dry as a nuns, so its back to thinkin'. Not a strong point of mine, but then wot is ha ha
One other thing - tried the rear brake light, no prob, switched the light on (fronts not wired up yet) and 'POP' fuse blown (single 20amp)
Do LED tail lights need a resistor? Its obviously shorting out somewhere, doubt its the loom (new) swiches are repo new as well but earth lead is prob of 75 vintage.
Any help/ pointers always appreciated for when i get my lazy arse in there.
I'll leave ya with this -
http://www.youtube.com/watch?v=4Ou-6A3MKow
Untill the next time, go easy
harry worth.jpg (19.29 KiB) Viewed 2364 times
Wots up DOHC
Z1parR
#79 PostAuthor: Z1parR » Mon Jun 18, 2012 11:10 pm
Hey sanderz glad you're back into it again , good to see you at the York rally , I even managed to post your mugshot on the rally thread :lol:
0172 . Geoff Parr
sanderz
#80 PostAuthor: sanderz » Tue Jun 19, 2012 6:31 am
Z1parR wrote:Hey sanderz glad you're back into it again , good to see you at the York rally , I even managed to post your mugshot on the rally thread :lol:
:bow Good to meet yer Z1parR, just had a look there, some crackin' photos - apart from my mugshot ha ha.
Just had a browse thro' some of the other projects as well, that have been posted in my absence - :wub excellant!
Wots up DOHC
#81 PostAuthor: Ginger Bear » Tue Jun 19, 2012 6:44 am
Great to see ya back Sanderz.
Led tail will not read a resistor, they are only used for indicators to 'fool' the relay into flashing at the right speed.
Seem's you've found yourself a garage too. :shock:
# 104
GUYZED
#82 PostAuthor: GUYZED » Tue Jun 19, 2012 10:24 pm
Welcome back mate :welc
#449
Z1000A2 Z650B1
sanderz
#83 PostAuthor: sanderz » Tue Jun 19, 2012 10:47 pm
Cheers GB, i'll go thro' the wiring diagram see what i've missed / done wrong - as usual it'll be operator error :oops: :kod
As for me little workshop - i had to build that when the bike was in the kitchen, bit cramped at times but im quite chuffed with it.
Ay up Guyzed :up
Yeh, im back in the real world :cry:
Seen a few pics posted of yer 650 - looks mint :drool (i've a fair bit of catching up to do)
Wots up DOHC
dela1340
seat
#84 PostAuthor: dela1340 » Sun Jun 24, 2012 9:16 pm
Hi what seatis on you bike or is it just a new cover is i have one the same but cover is u/s. Thanks
dela1340
seat
#85 PostAuthor: dela1340 » Sun Jun 24, 2012 9:22 pm
well that didnt come out as i typed it should have read =
Hi what seat is on your bike is it just a new cover or a standard seat as i have one the same but cover is u/s. Thanks
sanderz
#86 PostAuthor: sanderz » Sun Jun 24, 2012 10:32 pm
Hello dela 1340, the seat was originally from a Z1000A1 that the likes of M&P used to sell (its probably about 30years old) an ELR style.
The hinges are the same but i had to make a bracket for the lock area as its a Z1B and i dont have the 'seat stop' (the rod to stop the seat opening further) but doubt it would fit as the base hasn't any fixings there and the frame has 'alterations'.
The base on this one is 'good' but the cover has a small nick where the seat lock is - in short it'll do as is for me :wink:
If you need a seat recovering, a post in 'Bike Help' might show someone in your area or recomendations - im sure theres 1 in Preston and 1 in Northamton that forum members have used with excellant results :up
Hope this is of some use :)
Wots up DOHC
Mr Puffin
#87 PostAuthor: Mr Puffin » Sat Jul 07, 2012 3:28 pm
Hei Sanderz good to see you back/at it again :wink:
sanderz
#88 PostAuthor: sanderz » Mon Aug 27, 2012 2:21 pm
As usual very little progress on this - long term project could be replaced by lifetime project :oops: Seem to be more 'out 'n about than doing something in the shed but anyhow.....
A little background if yer want it
http://www.youtube.com/watch?v=cO-eTn8sSAk
Some months back i'd measured up for the rear brake, but being somewot of a lazy fekker, only recently put it together. Not normally a problem but this had me on the verge of slinging it over the back fence more than once :roll:
Rear caliper is early GSXR so its over 20years old but after a good clean (pistons out) and connecting it to an 'old' brake line and front master cylnder on some handlebars in the vice all moved freely.
So with new fasteners and bleed nipples connected the 'new' line, fresh fluid in, pumped it through - no pressure what so ever, repeat above and ....
Still no pressure...
Fred Dibnah 2.jpg (7.7 KiB) Viewed 2364 times
So as the song says "we was getting nowhere, so we had a cup of tea"
Suspect now was rear master cylnder (Brembo of a XJR13) took that apart, good clean out and .....nothing, same as, no pressure!
Long story short, after a lot of "fannying arond" it works a treat - dont know if it was 'airlocked' or maybe a spec of dirt in the transfer ports of the cylnder.... not sure??
Bled the system on the bench with the caliper higher than the lever- along these lines
Only other snag was after all the ON/OFF strpping it down, one of the wires on the pressure switch had frayed. So replaced that with a bajo bolt and had a root around the shed to knock summat up.
Found these -
Some folded ally sheet, heat sink, alloy bush and if your familiar with tattoo machines thats a needle (less tip) which is used then discarded usually.
So put together with an old switch i had this, it works so it'll do.
And on the bike with a few 'P' clips
While out'n about had these made up - useless really as its only a 6mm threaded rod through the spindle but hey ho, nothing ventured nothing gained. Didnt cost out, only time so i'll see how it all looks another day.
Oh and a little bracket for the tacho cable on the bottom yolk -
Last thing is a little purchase, been thinking about this for a while - well since i thought about taking the sump off, just for piece of mind since it was put together in the kitchen and the cutlery draw is missing a few teaspoons these days so.....
The low profile cover will give the exhaust collector more clearance and the oil pan gate will keep the oil where its needed.
......to be continued .....yawn, anyone still awake?
See ya
Fred Dibnah 1.jpg (7.91 KiB) Viewed 2364 times
This installment was brought to you with the aid of Yorkshire tea
Wots up DOHC
Crofty
#89 PostAuthor: Crofty » Mon Aug 27, 2012 10:20 pm
keep at it sanderz, lots of nice things on this one for sure. Crofty
Anuar Kamaruddin
#90 PostAuthor: Anuar Kamaruddin » Tue Aug 28, 2012 9:12 am
Always .never fail to thrill me with the cooking Sanderz. :)
