crankcases full of petrol
knut
#1 PostAuthor: knut » Fri Jun 22, 2012 5:50 pm
hi guys,
i was getting a strong smell of petrol from my gpz1100,tap was off and bike on side stand ,found petrol leaking out of carb #1 so propped bike up more upright with a bit off wood (no main stand )
turned engine over and petrol came fly out breather pipe,drained about 7 litres of petrol out of sump.
question,what do i do next ?change filter and refill with mineral oil run it up and change oil again with semi syntectic or am i in for a strip down ?
thanks in advance for your help knut
#2 PostAuthor: z1bman » Fri Jun 22, 2012 6:42 pm
first job is to drain the oil & filter with the bike in a upright position + leave to drain overnight with the filler cap removed. also remove the spark plugs + leave for the same amount of time. next remove the carbs + the fuel tank + drain. remove the fuel tap clean the fuel filter + inspect the diaphragm for any damage. you will then need to strip the carbs + inspect the float needle jets for any wear or debris. i would advise removing all the internals in the carbs + thoroughly clean them. next check the fuel levels you will need a special tool for this but is available from z power + not expensive . i would leave the carbs of the bike preferably clamped carefully in a vice for a couple of days linked up to a dummy tank just to make sure the carb fuel level does not start creeping up . then fill the bike with your preferred oil + a new oil filter
Jumbo
#3 PostAuthor: Jumbo » Fri Jun 22, 2012 7:16 pm
I had the same on my Z1100R vacuum tap was leaking. I fitted a pingel tap which has been fine.
With new fuels coming in and also the bike not being used all the time it seemed the best option.
LE to JOG on a z900
P.U.M.
big green bus
#4 PostAuthor: big green bus » Fri Jun 22, 2012 10:02 pm
the GPz taps are twatful Give it a clean in a sonic cleaner (Aldi) probably won't work but it will smell nice :roll: Remember to change the oil !!!!
Rhencullen
#5 PostAuthor: Rhencullen » Fri Jun 22, 2012 10:27 pm
You're lucky it didn't get into a cylinder and cause a hydraulic lock when you turned it over :shock:
As it is - you should be OK.
knut
#6 PostAuthor: knut » Sat Jun 23, 2012 7:20 am
thanks guys, yes first job is to inspect the needle valves and take it from there.thats what happens when the bike isn,t used everyday :roll:
#7 PostAuthor: Pigford » Sat Jun 23, 2012 7:04 pm
I had similar thing with me bestest Z1000 last year :shock:
Slightly different tho' - I cleaned me carbs (RS36's) and when re-assembling didn't do the pilot jets up :roll: Bike ran shite for a few miles (really rich) and when I got back the excess fuel had been blowing past the rings - at least thats what I put it down to - and the oil was fuel contaminated..... so must have run it like that a few times until I sussed the problem :shock: :??
So I changed the oil & filter - did the pilots up - and all been good since :wink:
