Blocked pilot Jets
malc87
Blocked pilot Jets
#1 PostAuthor: malc87 » Sat Jun 30, 2012 4:46 pm
Got the carbs off my Z1r and two of the pilot jets are blocked :(
Any tips or ways to unblock them?? :D
#2 PostAuthor: Pigford » Sat Jun 30, 2012 4:56 pm
Air line should do it :wink:
#3 PostAuthor: Ginger Bear » Sat Jun 30, 2012 4:59 pm
Probably gummed up Malc. A good soak in some thinners will help before 120psi goes through 'em.
# 104
malc87
#4 PostAuthor: malc87 » Sat Jun 30, 2012 4:59 pm
Pigford wrote:Air line should do it :wink:
Which of course I dont have :oops:
malc87
#5 PostAuthor: malc87 » Sat Jun 30, 2012 5:00 pm
Ginger Bear wrote:Probably gummed up Malc. A good soak in some thinners will help before 120psi goes through 'em.
I will get them soaking steve :D
Taffus
#6 PostAuthor: Taffus » Sat Jun 30, 2012 5:32 pm
send them to me and Ill run them them through my ultrasonic cleaner and blow them out with the airline if you want
T
malc87
#7 PostAuthor: malc87 » Sat Jun 30, 2012 6:05 pm
Taffus wrote:send them to me and Ill run them them through my ultrasonic cleaner and blow them out with the airline if you want
T
Cheers , I will do that if i get stuck.
:D
Ive got them soaking and going to take them around to my mates who has an airline tomoz
Garn 1
#8 PostAuthor: Garn 1 » Sun Jul 01, 2012 1:39 am
Malc87, if they are gummed up solid, like I have seen some, I don't think ultrasonic cleaning will clear them. Maybe thinners will dissolve the vanishes, I haven't tried that.
I had some success with soaking pilot jets for about 4 hours in a Yamaha product. Yamaha make two types of solution, one for putting in petrol and one for soaking and cleaning. The one I used was the latter, it had written on the plastic container "You will die if you breath the fumes".... I'm still alive and it did the job of dissolving the gum.
Regardz
jimmock
#9 PostAuthor: jimmock » Sun Jul 01, 2012 2:15 am
Malc,
Sounds like a FEW of my ex burds!!!!!!!
Jimmock. :wnkr
I hate people I don't like !
malc87
#10 PostAuthor: malc87 » Sun Jul 01, 2012 8:43 am
Two jets are clear , the third seems to have a slight blockage and the 4th is almost (but not quite :D) fully blocked?
The main jets were perfectly clear and the float bowls were spotless?
Fuel tap is also perfectly clear :D
jets are soaking at the moment :wink:
jimmock
Re: Blocked pilot Jets
#11 PostAuthor: jimmock » Sun Jul 01, 2012 11:47 am
malc87 wrote:Got the carbs off my Z1r and two of the pilot jets are blocked :(
Malc,
The best way to clean them is,....
Drill them out with a 1/8 th drill!!
Glad to be of help AGAIN.
Jimmock. :wnkr
malc87
#12 PostAuthor: malc87 » Sun Jul 01, 2012 12:30 pm
Malc,
Should the drill be set on "Hammer"?? :?:
#13 PostAuthor: Pigford » Sun Jul 01, 2012 2:38 pm
Don't be siily Malc :roll:
Anyway, you tight git - buy some new ones off Allens Performance :!:
sid123
#14 PostAuthor: sid123 » Sun Jul 01, 2012 2:42 pm
get some carburetor cleaner from any motorist discount / halfords store
spray this in and let it soak it will dissolve the gums and residues keep applying until gone ( dont get it in cuts or eyes it stings like hell )
Sid
whoosh im gone
malc87
#15 PostAuthor: malc87 » Sun Jul 01, 2012 3:05 pm
LEFT THEM SOAKING, AND THEM USED CARB CLEANER AND AN AIRLINE.
ALL NOW CLEAR :D
NOW JUST THE H1R TO GET READY FOR MALLORY NEXT WEEKEND
LAST MINUTE.COM :roll:
